What should a 12v battery cost me? dead after 56K mi & 23 months. Dealer says $458
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Michelle S, Sep 14, 2018.
  1. Mendel Leisk
    41,301
    I heard somewhere that the price of batteries was going up due to milder winters, which in turn lead to batteries lasting longer, which meant less recycled lead, so the cost of lead is going up.
    I'm sure I read it from a credible source, but have to admit it sounds a little far fetched. Anyway, the bottom line being that colder winter were tougher on batteries, led to more replacements.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    Yeah, but the battery in a hybrid doesn't crank the engine at all, it's just there to boot up the computer. So the cold cranking amps number is next to useless. When I need to replace mine, I'm gonna get one that has the highest Ah rating.
  3. Indy317
    Indy317 Junior Member
    Indiana
    Two Eco
    Just had it replaced in 2015 Prius at the dealership here in Indy. Cost was $252 and that included labor to install. With coupon brought it down to $232.
  4. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Id be surprised if you couldnt find one at a local auto parts store.
    Autozone, Advanced, PepBoys, Oreillys etc all have batteries for Gen IV Prius so yours being older should have even more options
    The cheapest one currently is the Champion battery at Pep Boys for 99 bucks.
  5. Mendel Leisk
    41,301
    3rd gen vs 4th gen battery is a factor too. The 4th gen's are conventional lead-acid, but a special shape, not that common, hard to find. And with the 4th gen being newer, demand for replacement batteries just staring to pick up.
    krmcg likes this.
  6. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    A few weeks ago Pep Boys had the battery for a Gen. 4 for $100 installed by ordering it on line. The size is a H4.
    I hope this helps.
    krmcg and Mendel Leisk like this.
  7. Elt31987
    205
    155
    Derry, NH
    Still is
    krmcg likes this.
  8. bisco
    51,837
    gen 4 thread
  9. David E. Edwards
    25
    Sugar Land, TX
    Try Pep Boys, as low as $100 for the H4 battery for the '16 forward.
    krmcg and Elt31987 like this.
  10. Solarj
    Solarj Junior Member
    Central Arkansas
    Yes! I put an H4 from Oreillys in my 16 and has worked perfect.
