Bright lights not coming on?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mikes951, May 1, 2018.
  1. mikes951
    mikes951 Junior Member
    46
    US
    i hit a racoon on the driverside and it tore up the inerfender over the tire the whole thing was out in the road anyone might know whats wrong?thanks
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Wire loom damage... you think?
  3. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    I hit a cat last year. Tore the inner fender off and did 1125$ damage.
    What did the racoon cost????
  4. mikes951
    46
    US
    you think both high beams lights went out the same time?
  5. BZzap!
    1,607
    878
    All it take is one main ground wire.
  6. mikes951
    46
    US
    Following up on this both high beams replace works great.
  7. bisco
    52,390
    well done!(y)
    mikes951 likes this.
