Which Hybrid Battery Pack Would You Choose?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010_Prius_Bro, Oct 12, 2018.
  1. 2010_Prius_Bro
    2010_Prius_Bro Junior Member
    44
    maryland
    Hi Guys. I am planning to purchase a salvage yard battery pack for my 2010 Prius. I have two to choose from: 2015 Prius with 70k miles or a 2013 Prius with 59k miles. Both are the same price. I am leaning towards the newer battery back even though it has a little bit more mileage. Which would you choose and why?
    iPhone ?
  2. davecook89t
    davecook89t Senior Member
    1,086
    820
    Washington State, Florida
    Four Touring
    Right, most of us believe age is more important than miles. I would also go with the newer one. If you have the opportunity to take the cover off the pack you are buying, check that the modules have similar date codes to be sure none of them have been replaced with older ones.
    bisco and 2010_Prius_Bro like this.
  3. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    You have a gen2 Prius, both packs are from a gen3 Prius, the HW/SW (hardware/software) interfaces are different, if you plan to replace individual modules, good luck.
    The newer the better.
  4. davecook89t
    1,086
    820
    Four Touring
    No, 2010 is the first year of Gen 3. He should be able to swap the pack straight in either with or without the electronics.
    IwasBirchyFirst likes this.
  5. 2010_Prius_Bro
    44
    maryland
    Hi Usle, thanks for your reply but my 2010 is a 3rd gen.
  6. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Thanks.
    Facts matter.
    davecook89t likes this.
  7. Luckykat32
    Luckykat32 Junior Member
    22
    So Cal
    How much are the salvedge yard battery packs? ...might be a temporary option for me too
  8. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    If you don't mind me asking. How much are salvage yard batteries?
  9. bisco
    51,774
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    +1;).
    How many miles on your 2010? What’s wrong woth your current pack :whistle:?
  11. 2010_Prius_Bro
    44
    maryland
    My Prius has 206k miles. The battery packs cost $900.
    iPhone ?
    #11 2010_Prius_Bro, Oct 13, 2018
  12. 2010_Prius_Bro
    44
    maryland
    I have the PA080 error code. I already swapped 6 modules 2 months ago but the code just came back so I am just looking for a salvage battery pack which will definitely last longer.
  13. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    I'd check dealers for a new pack it should be around 1600$, after the core deposit refund, no three year warranty because you're installing, just one year, but new.
