Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    No worries;).
    My recommendation will remain the same(y).
  2. aterfy27
    aterfy27 New Member
    Illinois
    I'm embarrassed at how long it took me trying to figure out how to get the fuse box positive terminal cover off before finding the video... Watched video, done in 2 seconds.
    What in god's name are those two clips on top of the cover for?!?
    Mendel Leisk and NutzAboutBolts like this.
  3. lw4nier
    lw4nier New Member
    usa
    Are there any instructions how to remove the throttle body? I really want to take it off to clean. But all I have seen is wiping it off with brake cleaner, which doesn't look like a good cleaning to me.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,497
    1,593
    Bay Area
    If you watch our intake manifold cleaning video, we removed the throttle body. :)
    #224 NutzAboutBolts, Aug 6, 2018
  5. Mendel Leisk
    40,457
    You don't really gain much by removing it to clean, you can clean it fine without removal. But yeah you can easily remove, and you can leave the coolant lines attached, there's a fair bit of play. Torque on the bolts/nuts is 7 foot/pounds.
    lw4nier likes this.
  6. lw4nier
    lw4nier New Member
    usa
    I got a little crazy and removed the PVC plate. Looks like it had some kind of gasket seal. So i cleaned it up, It wasn't too bad and now reinstalling it. I used some gasket maker around the plate and screw holes. But does anyone know the torque specs for the pvc plate? Their are about 8 screws holding it.
    Thanks
    And removing the throttle body worked! thanks for the replies!
  7. Mendel Leisk
    40,457
    How hard was that? I tried prying on it half-heartedly, seemed like it was glued on pretty good.
    You motivated me to look: attached is the Repair Manual info on that. It's lumped in with engine disassemble/reassemble, and I'm not adept at Acrobat PDF creation, just cobbled together all the pages having the info, plus some extraneous stuff, but it's all there.
    A screen grab from the last page:
    I see the "Toyota Genuine Seal Packing Black, Three Bond 1207B" is available on Amazon.
    #227 Mendel Leisk, Aug 13, 2018
    frodoz737 likes this.
  8. lw4nier
    lw4nier New Member
    usa
    Thanks for the service manual info Mendel!
    It took a little muscle removing the cover. I finally got a small pop from the bottom left corner. Then just kept going till it came off. I was expecting more oil/carbon sludge from a 2012 with 146,000 miles. Don't think it was worth the trouble and probably won't do it again.
  9. NutzAboutBolts
    1,497
    1,593
    Bay Area
    #229 NutzAboutBolts, Aug 14, 2018
    m3pare, Rebound, RMB and 3 others like this.
  10. NutzAboutBolts
    1,497
    1,593
    Bay Area
  11. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Finally started modding your Prius :).
    What’s the next mod:whistle:?
    NutzAboutBolts likes this.
  12. NutzAboutBolts
    1,497
    1,593
    Bay Area
    Lol not really modifying too crazy.
    Bay Stater and Raytheeagle like this.
  13. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    #233 Raytheeagle, Oct 13, 2018
    jjmerp, RMB and Bay Stater like this.
  14. NutzAboutBolts
    1,497
    1,593
    Bay Area
  15. Mendel Leisk
    40,457
    Years back, wandering around a Honda dealership lot on Sunday (when they were closed) looking at the offerings, I started noticing bolts all over the place. Enlisted my kids and we picked up a bunch, various metric bolts. Nice gold-coloured bolts, most with captured washers. Still have most of them, just a handful or two. :)
    Raytheeagle likes this.
  16. NutzAboutBolts
    1,497
    1,593
    Bay Area
    That’s smart lol
  17. NutzAboutBolts
    1,497
    1,593
    Bay Area
    Here’s comparing the halogen bulb to the LED headlights for you :)
  18. Mendel Leisk
    40,457
    Have you guys ever changed the stock LED headlight bulbs? Or maybe they rarely fail?
  19. NutzAboutBolts
    1,497
    1,593
    Bay Area
    our Stock bulb is halogen, not LED.
  20. NutzAboutBolts
    1,497
    1,593
    Bay Area
    Just an FYI guys, I'm doing a LED giveaway on our Instagram page. Just leave a comment down below on the post and you can enter. We only ship in the united states, sorry for out of the country guys :(
