Tire pressure gauges, I bought 2 new ones, reading is way off from my old one
Discussion in 'Gen 3 Prius Main Forum' started by Jeffrimerman, May 28, 2018.
  1. Mendel Leisk
    40,461
    Interesting:
    Jeffrimerman likes this.
  2. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    that's a really cool video. Mine is exactly like that. I would hate to throw away what used to be a nice gauge. I imagine over decades there is metal fatigue. I won't mess with it until I compare it to a nice gauge.
  3. Salamander_King
    Salamander_King Senior Member
    11,004
    8,925
    New England
    Now, this begs me a question. How accurate is the TPMS sensor's pressure measurements? Doe they stay accurate for the life of device, say 7-10 years?
  4. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Their batteries last 5-10 years I've read and more like 5-6 years for older ones so I wonder that also. After 7 years is it 3 more years of inaccuracy?
    Salamander_King likes this.
  5. Salamander_King
    11,004
    8,925
    New England
    Being digital, I wouldn't tink low battery causes inaccuracy, just an error for not receiving signal. But if there are any mechanical parts inside of TPMS pressure sensors, then old age may affect accuracy? Or worse yet, are all the TPMS sensors accurate to begin with?
  6. Mendel Leisk
    40,461
    Learned something, regarding the stick-style pressure gauge mechanism. Inside there is a spring, and a rubber piston, both of which could wear/fatigue. It seems like my stick-style have always stayed reliable though. Maybe some complacency on my part.
    How Tire Pressure Gauges Work | HowStuffWorks
  7. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
  8. mysticeyes
    mysticeyes Junior Member
    Maryland USA
    I've got old analog gauges, and this discussion is encouraging me to try Tire Assistant, another app from the people who created Hybrid Assistant. Tire Assistant is supposed to display pressures from TPMS sensors (for Toyotas and Lexii only) through a Bluetooth OBD connection.
  9. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    If I order an $8 bluetooth obd2 I wonder if it's fine for using that or other apps like that. This would be the best thing.
    Edit: I used my toyota software on my laptop and connected to my obd port and got 39.5 psi for 3 tires and 39.1 for one tire. My cheap 2 for $10.99 digital tire gauges were within 1 psi of that, more like .5psi so for sure my old gauge was way off from the tpms. My $3.99 harborfreight analog was with .5psi also. I ordered an ELM327 bluetooth dongle but who knows if that will work with the software mentioned. For $3 it's worth a shot.
    #29 Jeffrimerman, May 29, 2018
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Everything wears out over time.
    I would stop by your local tire shop and ask them to check your tire pressure, see what they say it is, then compare it to what your readings are on your new and old gauges. You can be honest, and just tell them, you're trying to figure out if you tire gauges are accurate.
    Mendel Leisk and Bay Stater like this.
  11. fuzzy1
    10,335
    Now I'm wondering: does TPMS measure gauge pressure, or just absolute pressure?
    Last winter's ScanGauge update showing TPMS values is always waking up in my car with (-14.5) psi -- negative pressure -- which suggests that it is receiving an absolute value and then subtracting a fixed typical sea level pressure. And I'm seeing a negative number because the car has not yet read any sensors, so is starting with a zero placeholder before applying the subtraction.
    Tires want gauge pressure, not absolute pressure. So if this is what is happening, then TPMS values will vary significantly more than +/- 1 psi from gauge readings simply due to external barometric and altitude changes.
  12. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    The gauge and my tpms show the same pressure but maybe that's doesn't mean anything. When I had the sensor out of the tire I could squeeze it to make it think there was enough pressure and it caused the warning lights to turn off but again that doesn't mean it isn't using atmospheric pressure in it's equation. When I checked with my computer at the obd and all sensors were out of the tire it showed 0 pressure not a negative amount.
  13. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    I have the pencil type stick guage (Milton) that I bought right after getting the car. Then I bought the Accutire digital one. There's always a 4 to 6 psi difference. I don't know which one is more accurate.
    I like the stick guage for its simplicity, and it's cheap enough to replace often. The digital guage has a battery, and is kept in the hot car all the time. That's probably not good.
  14. Salamander_King
    11,004
    8,925
    New England
    My several handheld tire gauges (including cheap mechanical pencil type and digital one, somewhat more expensive mechanical and digital one) and also in-line gauge on a few inflator both portable and at gas station are all over the values (± 5psi), I have no idea which one to trust. So, to monitor more accurate tire pressure on my PRIME, I have been using external TPMS like the pic for a few month now. It works great when they are functioning correctly. Comparing the reading of external TPMS to the internal OEM TPMS reading from OBDII using Tire Assistant app, the differences are ± 1psi.It is far better than OEM TPMS that does not display actual number, or phone app via OBDII that can not be used while car is moving. The problem is that those aftermarket TPMS are cheaply made and not very durable. I had one sensor fail only after a few weeks of use and had to return the entire unit. Got new one, but seems to be having some sensor-display unit communication problem again. Since sensors are pre-programed with the display unit and you can not purchase a single sensor to replace a failed one, if one sensor fails, you have to purchase entire unit at ~$50. I was hoping the unit to last at least a few years, but that seems to be wishful thinking.
    #34 Salamander_King, Oct 19, 2018
  15. Starship16
    1,348
    1,455
    Beach Christmas
    (Photo from ConsumerReports.org.)
    How do you know if the battery is low? Does the screen go black? I get a very different reading using this Accutire gauge.
  16. Mendel Leisk
    40,461
    Maybe I'm just lucky, but for a while I had a couple of stick gauges and a cheap digital, and they were all pretty close. The one I'm only using now is a solid, made in the US stick, probably will outlast me. The one issue I've noticed is the rubber gasket that presses against the valve stem starts to dry out, get brittle. It'd be nice to have a source for replacement gaskets.
  17. Starship16
    1,348
    1,455
    Beach Christmas
    Yes, I have no problem with the Milton stick gauges. I have 2 new ones. $6. Just wonder why the big difference in psi when using the digital one. (I think the ACCUTIRE gauge was recommended by Consumer Reports.)
  18. padroo
    padroo Senior Member
    2,763
    2,251
    Starship16 likes this.
  19. Salamander_King
    11,004
    8,925
    New England
    Ordered MS-4021. Will see how it works.
  20. Mendel Leisk
    40,461
    I'm pretty sure mines Milton too. I'd check but i ate a big plate of spaghetti, pretty much immobile.
    Addendum: Yeah mine's a Milton. As I already said, on page 1. Repeating myself. :oops:
    #40 Mendel Leisk, Oct 19, 2018
