Excessive oil consumption. Issue resolved by Toyota.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ctt, May 24, 2016.
  1. Mendel Leisk
    40,467
    You have to stare into space here, can't lock the pump on, at self-serve. And I've seen one instance too many: a locked on pump (at a full-serve), just AGUSHING, for about 3~4 minutes before an attendant noticed.
    But yeah, plenty of opportunities besides fill up time, to do checks.
  2. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    There’s another thread like this but ford solved it. Both this and the Ford thread are misleading, fake news headlines at its best.
  3. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    What’s that? Poking glass?
  4. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Oil brand?
  5. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Good old Mobil 1. Extended Performance 5W-30, to be exact. Guaranteed for 15,000 miles. :ROFLMAO:
    But I still change it twice a year. And I drive like an old man, so thus I get better gas mileage than all you young crazy dudes. :LOL: I got nothing but time.......
    #105 Starship16, Sep 9, 2018
    Tande likes this.
  6. frodoz737
    frodoz737 Top Wrench
    4,506
    2,426
    33
    OK then...3 extra minutes. ;)
  7. Starship16
    1,348
    1,455
    Beach Christmas
    It takes me 3 minutes just to EXIT my little Disneyland car! ;) :ROFLMAO:
    I need to spread all those chores out.
    One day, check tire pressure. (15 minutes)
    Another day, check oil and fluids. (5 minutes -- the Mendel five minute rule)
    A third day, wipe & clean all windows. (6 minutes)
    Fourth day, buy gas? Nah, I'm driving a Prius!
    Darn, I still got 4 days left in the week!
    #107 Starship16, Sep 9, 2018
  8. macondo100
    macondo100 Junior Member
    40
    US
    I've got a 2006 Prius with 155K; started having the same issue on/around 130K miles and now I'm burning 1 qtr. every 1k miles; seems like a big issue with these vehicles; I've been religiously changing oil every 5K miles, changed spark plugs and PCV, put an oil catch can hoping to catch most of this oil but it seems that the engine is just burning up the oil; the car is 12-13 years old so not worth taking it to the dealership; seems I'm not alone with this issue; Toyota has got to do something about it.
  9. Mendel Leisk
    40,467
    Maybe combine those two: pull the dipstick, then check the pressures, then get back to the dipstick.
  10. danlatu
    danlatu Senior Member
    533
    1,361
    maryland
    If your not catching a lot in the occ, clean/replace your pcv. You may be burning oil from your valve guide seals.
  11. macondo100
    40
    US
    I'll do that; I replaced the PCV at 135K though for the same issue of too much oil consumption.
    danlatu likes this.
  12. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Sometimes I get scared when I see oils that can be used for 15000miles, and in your case only needs to be replaced twice a year.
    After those miles and years, how does the oil drained always looks like? Does your maintenance required light comes on, before those 15000miles, or it does not lit at all?
    I ha e only heard of 5000miles, or something for oil change. Something new to me in our part of the world(Lagos).
  13. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    I checked my oil twice today while on my trip back home, and this thread makes me want to go check it again!! It hasn’t used enough to read on the stick since I changed it two weeks ago, but I still want to go check it.
  14. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    You can read it by using my paper towel method.
  15. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    I mean the level hasn't changed enough to see a difference. And yes I did go check it again. That’s three times today. :)
  16. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    15000 in a Prius and there'd be no oil left if you didn't add any haha
  17. douglasjre
    douglasjre Senior Member
    2,087
    698
    Null, NL
    How much of a difference did changing the valve make
    SFO likes this.
  18. Peter123
    Peter123 Active Member
    131
    128
    Has anyone tried to do a chemical attack on the carbon deposits in the engine. The oil consumption is usually caused by build up on the piston rings. There are 2 easy things you can do. They will not return the engine to new condition, but they will help.
    1) Use Cataclean in the fuel. This product cleans catalytic converters. It has a side effect of cleaning the carbon deposits in the engine, intake manifold (from the injectors into the valves), and the exhaust manifold. This will erode the ring deposits from the combustion side.
    2) Use Motor Flush in the oil at the next oil change to clean the rings from the oil side.
    I would also recommend checking the EGR system for deposits. Toyota uses cooled exhaust gas through the EGR valve to help limit the combustion chamber temperature. Once the EGR fouls up the temperature rises and you get fouled rings and the attendant oil consumption problem.
    RMB and mjoo like this.
  19. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Raytheeagle done #1 & #2 and has a good scope of EGR knowledge.
    RMB and Raytheeagle like this.
  20. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    A certified mechanic described doing this to his Gen2 here
    Pixel XL ?
    #120 mjoo, Oct 31, 2018
