Is it a pain to plug in everyday?
Discussion in 'Prime Main Forum (2017-2022)' started by coach81, Oct 18, 2018.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    This is an excellent point.
    In my case, we have a charger (EVSE technically) right next to the charge port of each car.
    The cable is hanging right on the wall, and a button on the end of the charge cable opens the flap on the car’s charge port.
    It takes about 5 seconds to plugin or unplug. The charge port door then automatically closes.
    As stated, if you have to dig out a bunch of cord, plug it into an inconvenient spot or similar issues, it could be inconvenient.
    None of the OEM solutions will allow the car to shift into gear while plugged in, so no worries about driving away with the cord attached.
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Wow, I want the automatic port door closure function on may PRIME.:love: I don't know how many times I have disconnected the EVSE and stored away. come back to the car and sit on the car, close the door and START the car, only to see the "charge port door is open" warming on the display. Have to get out the car and close the port door. I've never tried this, but does PRIME let someone to drive away with the port door open?
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Plugging in and charging my Prime several times a day is like closing the door on your car or house, and locking up. With the L2 charger right next to the Prime's charging port, it's a 4 second exercise. I would much rather do that, than face all the animals at the gas station and fiddle around for 20 or 30 minutes down there!
    I used to have to do this 2 or 3 times a week with economical ICE vehicles; never more!!
    AChoiredTaste.com
  4. CharlesH
    2,796
    1,163
    Roseville, CA
    On the first generation Plugin, the plug cap was built into the charger door, so there was nothing to do: shut the charger door, and the plug cap was set. Then they went backwards with a separate plug on the Prime. :rolleyes:
  5. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Not a pain at all. I would rather plug in than stand at a gas pump filling up. I have a set up at home so all I have to do is grab the charging cord hanging there and bam...it is charging.
    jerrymildred and HPrimeAdvanced like this.
  6. El Dobro
    El Dobro A Member
    7,088
    3,270
    Or as it is I NJ, waiting for the gas jockey to come over (hopefully putting down his cigarette and cellphone), figure out what you want and then, start to put the gas in at the high speed setting (having it click off 4 or 5 times until he sets it at a slower speed). In the mean time gas is spilling over the side of your car while he's setting someone else up.
    fuzzy1 and HPrimeAdvanced like this.
  7. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I use an L1 charger an am afraid of my outlet exploding (past experiences) so I have to plug the plugin the wall then plug it into the car so I find its a bit of a drag to plug it into the wall as its like its kinda hard cause I have to lean over the car and plug it in. But when I'm at an L2 station its a pleasure to plug it in as I know I'm not adding gas:ROFLMAO:
  8. Guy in WNY
    Guy in WNY Junior Member
    83
    17
    Western New York
    2018 Prius Prime
    If I only had another 10k saved up, I would have the Tesla M3 in my driveway, not the Prius. Have to start saving again, and wait 5 years. Oh well.
    coach81 likes this.
  9. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    You're not going to be able to buy a new Tesla M3 for $10k more than your Prime Premium right now. How long has the M3 been out and how many have they sold and there's still no $35,000 car yet?
  10. coach81
    coach81 Active Member
    758
    116
    Louisiana
    With the standard plug I think it will be a bit of a pain to deal with the cords and such... but if I invest in a L2 it will be extremely close to the vehicle and not be a problem at all.
  11. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    It all depends on your set up. If you make it easy for yourself with a plug close at hand, it's easy. If you have to drag cords to get it done, not so easy.
    Even if you don't plug it in often, or ever, the Prime is a better hybrid due to its larger battery.
    Have you spoken with many Tesla owners? My wife's cousin had a Model S. Really liked it. Dumped it because it was such a long wait to get service. Things like brakes and window motors were not easy to get fixed. No one else will work on Teslas, and the company did not ramp up service as they increased sales. It's gotta be worse now with the Model 3s coming out. A friend of the cousin bought a top-dollar new Model S. In two weeks the wiz-bang electronic door handle failed. He had to crawl across the console to get in & out. 2 week old car, and they gave him a repair appointment 4-1/2 weeks out. He sold it for a big loss. Cousin had the problem of trading in the Tesla. The Porsche dealer wouldn't take it. He traded it to an BMW dealer that he knew. If (when) Tesla goes bust, no one is making parts nor knows how to repair them, they'll be real white elephants. Tesla will go broke when investors lose faith in Musk and stop lending him money.
    When I see a Model 3 on the road for think of an Amphicar. Something about the looks....
    #31 PT Guy, Oct 20, 2018
  12. Curlyone
    Curlyone Member
    60
    Arkansas
    This is the main reason I decided on a L2 charger. I have a car port and was concerned about someone stealing the plug in charger, it was a pain to plug/un-plug from the wall every time. I knew at some point I would get tired of it and get out of the habit of plugging in, not to mention the wear and tear on the wall socket. For me it was money well spent as it takes just seconds to plug in now, and I've found the shorter charge time to come in handy.
    coach81 likes this.
  13. coach81
    758
    116
    Louisiana
    This will probably be me...
    HPrimeAdvanced likes this.
  14. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Well it was actually more of a pain (if you want to call it that) when I used the car's charging cable. But I didn't really mind it. I'm lucky and I have an L2 charger at my office and one at home. So it's just habit to plug in the cars when I get home. My other family car is a Bolt so we have to sometimes swap them when one or the other is done charging.
  15. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    I plug in about 4X per week as I do not have to work every day. But since car is garage kept at home, no worries plugging in. I have a 70 plus mile commute 4 days a week round trip. So not having to use gas in the spring/summer one way has really helped on mpg. So far this fall I have been losing 10 miles of range so that will continue to drop as temps keep falling here in the northeast. I have been averaging close to 1000 miles between fill-ups and it costs less than $30 to fill up anyway. Beats the crap out of my SUV which needed premium gas every 4 days or so!
    HPrimeAdvanced and benagi like this.
  16. bresna
    bresna Active Member
    193
    144
    Southern Maine
    It's a bit of a pain for me. I park outside and when it's raining, snowing or cold, you really want to just hoof it into the house. Instead, you have run to get the cord, run back out, plug it in (hoping that all those safety features on the charger work) and then go back into the car, get the stuff you want to bring in and then you're done.
    It'd be so much easier to just grab the stuff to go in and... go in. :)
    coach81 likes this.
  17. KCWhitney
    KCWhitney Active Member
    134
    116
    Connecticut
    2025 Prius Plug-in
    It's as big a pain as you choose to make it. It you get yourself a level 2 charger and locate it conveniently close to where you park your car, it is not a pain at all. It is certainly less of a pain than driving to the gas station, and paying money while waiting in the cold for the tank to fill up, breathing poisonous fumes all the while.
    HPrimeAdvanced and Zythryn like this.
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Come on...
    Pain to Plug In?
    That's a 1st world problem.
    Trust me, if I had the resources and environment that allowed me to own and operate a plug in vehicle?
    Well, plugging it in...would be a pain I'd love to have.
    Seems to me the benefits of owning a Plug In far outweigh having to plug it in.
  19. bwilson4web
    16,204
    Is that the 2016 Tesla Model S 75 RWD with 18,322 miles in Pasco, WA?
  20. Jeff Cohen
    Jeff Cohen Junior Member
    Dallas, TX
    2003 Prius
    Not at all. It has become a habit. Eight o'clock comes with free electricity and I plug in. Didn't want to fiddle with the programming feature. My wife plugs her Leaf in once a week. No problem there either.
