Gen 1 2001 prius in mint(y) condition in junk yard
Discussion in 'Generation 1 Prius Discussion' started by prius_deep, Oct 20, 2018.
  1. prius_deep
    prius_deep Member
    105
    road
    saw this 2001 green prius in minty fresh condition :sneaky:in a junk yard. Does not look as if it has been hit, or that it has hit any other car. Clean interior with prius label floor mats, owners manual, and original battery(?). Clear air filter, they didn’t remove the brake fluid see pictures.
    Maybe the battery finally died, or it needed one more repair that was the final straw.
    it’s green so it’s in minty fresh condition ;) been there 2 weeks; still intact; cat gone.
    Just like mint OS is in minty fresh condition (y).
    p1st_001.jpg p1st_002.jpg p1st_003.jpg p1st_004.jpg p1st_005.jpg p1st_006.jpg p1st_007.jpg p1st_008.jpg p1st_009.jpg p1st_00010.jpg p1st_00011.jpg p1st_00012.jpg p1st_00013.jpg p1st_00014.jpg p1st_00015.jpg
    m.wynn likes this.
    50,815
    grab it!
    m.wynn likes this.
  3. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    You CANNOT be serious! That car is in a junkyard for a reason!! :LOL:
  4. ChapmanF
    16,959
    tochatihu likes this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Seen many head to the junk yard for bad motors, bad transmissions, or bad hv batteries.
    Grab the VIN and check Toyotaowners.com and you may find some history.
  6. prius_deep
    prius_deep Member
    105
    road
    After looking at the pictures some more. The front wheels appear to be straight, but look at the steering-wheel - it’s turned left. Maybe the steering broke? Or very bad alignment?
    I am looking for a 2016 to take the rims off. Last year it was $75 to change tires back to OEM, today it was $80 to change to ~winter~ tires, I keep cars a long time, get the rims(and have the other tire set installed on said rims), save money in the long run – I'll switch my own tires, seasonal change prices will only go up.
    SFO likes this.
  7. bisco
    50,815
    i find it amazing that the bodies aren't rusted out. i see a lot of mint gen 1's on the road, and a lot of rusty honda's circa 2000.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,262
    15,506
    Bay Area, California
    2019 Prius Prime
    Come out here and you’d see all te remaining gen1’s in no rust condition;).
    The drivers are the maker for cars here:eek:.
    I almost lost our 2010 Friday on the way to work. An old Chevy work truck wanted to go 3 lanes over to the faster lane and just missed my front bumper and ended up clipping the truck next to me:cool:.
    His hurried ness went punished and we’ll deserved(y).
    SFO, m.wynn and bisco like this.
  9. bisco
    50,815
    glad he missed you!:)
    m.wynn and Raytheeagle like this.
  10. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    Me too;).
    I was on the speaker phone with my old man when I had to take evasive action:eek:.
    Had to call him back and he was thankful(y).
  11. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Where is it?
  12. prius_deep
    prius_deep Member
    105
    road
    steering is OK wheels turn.
    pcgr001.jpg pcgr002.jpg pcgr003.jpg pcgr004.jpg pcgr005.jpg pcgr006.jpg pcgr007.jpg
  13. bisco
    50,815
    that's a funny location
  14. ChapmanF
    16,959
    If the steering's in OK the wheels are probably there too, unless it's in a very funny location and they're in KS, MO, AR, TX, NM, or CO.
  15. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    As much as I like my 02, this makes me sad. It is a nice car that should have been rescued. Where is it located? If it were in Phoenix, I'd take a boatload of tools and rescue parts. I'm in Tucson.
  16. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Dealer records span from 4/28/05 to 4/19/17.
    4/19/17
    Dealer
    Northbrook Toyota
    162,152
    Repair Order Number: 0253835
    PULLED MULT CODES P3101-206,3120,250,3191 CLEANED OUT THROTLE TO START CPODESA CAME BACK RECCOMEN ~|~CHECK ENGINE LIGHT CAME ON ALONG WITH LOW COOLANT LIGHT HARD TO ACCELRATE VEHICLE PULED OVER AND TOWED IN ~|~, PULLED MULT CODES P3101-206,3120,250,3191 CLEANED OUT THROTLE TO START CPODESA CAME BACK RECCOMEN,PERFORM M.P.I. MULTI-POINT INSPECTION
    VIEW DETAILS
    12/15/16
    Dealer
    Anderson Toyota
    157,643
    Repair Order Number: 0320331
    CHANGE OIL AND FILTER, ROTATE TIRES PERFORM MULTI-POINT INSPECTION
    VIEW DETAILS
    2/20/16
    Dealer
    Anderson Toyota
    144,325
    Repair Order Number: 0300375
    VIEW DETAILS
    12/26/14
    Dealer
    Anderson Toyota
    133,498
    Repair Order Number: 0274833
    CHANGE OIL AND FILTER, ROTATE TIRES PERFORM MULTI-POINT INSPECTION,REPLACED INOP LIC PLATE BULBS, REPLACE SERPENTINE BELT
    VIEW DETAILS
    6/12/14
    Dealer
    Smart Toyota
    129,365
    Repair Order Number: 0659807
    INSP VALVES AUDIBLY, REPLACE COOLANT,INVERTOR COOL GEN 1, SPARK PLUGS R&R,MAINTENANCE INSPECT, BODY ELECTRICAL EXT, COMMENTS, *FRT BRK PADS/REP RT,THROTTLE BODY SERV, RPL AIR FILTER, P-C-V VALVE
    VIEW DETAILS
    11/26/13
    Dealer
    Anderson Toyota
    128,023
    Repair Order Number: 0251542
    DIAGNOSED AND REPLACED 12 VOLT BATTERY
    VIEW DETAILS
    9/29/11
    Dealer
    Anderson Toyota
    107,038
    Repair Order Number: 0210842
    CUSTOMER STATES CHECK ENGINE LIGHT IS ON NOW OR HAS BEEN ON, RPL PS GEAR ASSY IF LEARNING FAILS OR MIL AT FINAL CHK
    VIEW DETAILS
    5/5/09
    Dealer
    Anderson Toyota
    82,946
    Repair Order Number: 0157409
    OIL & FILTER SERVICE
    VIEW DETAILS
    11/6/08
    Dealer
    Anderson Toyota
    79,336
    Repair Order Number: 0146541
    OIL & FILTER SERVICE, WIPER INSERTS,ELECTRICAL, DRIVEABILITY, DRIVEABILITY,DRIVEABILITY
    VIEW DETAILS
    8/5/08
    Dealer
    Anderson Toyota
    77,541
    Repair Order Number: 0140798
    VIEW DETAILS
    3/26/08
    Dealer
    Anderson Toyota
    74,703
    Repair Order Number: 0132379
    75,000 MILE SERVICE
    VIEW DETAILS
    11/8/07
    Dealer
    Anderson Toyota
    72,141
    Repair Order Number: 0124210
    OIL & FILTER SERVICE, ENGINE MECHANICAL,WIPER INSERTS
    VIEW DETAILS
    5/31/07
    Dealer
    Anderson Toyota
    68,386
    Repair Order Number: 0113697
    OIL & FILTER SERVICE, BRAKE REPAIRS
    VIEW DETAILS
    1/25/07
    Dealer
    Anderson Toyota
    64,780
    Repair Order Number: 0105911
    67,500 MILE SERVICE
    VIEW DETAILS
    12/12/06
    Dealer
    Anderson Toyota
    63,752
    Repair Order Number: 0103290
    63,750 MILE SERVICE, WIPER INSERTS
    VIEW DETAILS
    8/31/06
    Dealer
    Anderson Toyota
    60,467
    Repair Order Number: 0096989
    RECALLS
    VIEW DETAILS
    6/15/06
    Dealer
    Anderson Toyota
    58,573
    Repair Order Number: 0092221
    60,000 MILE SERVICE
    VIEW DETAILS
    1/19/06
    Dealer
    Anderson Toyota
    54,580
    Repair Order Number: 0084326
    VIEW DETAILS
    9/8/05
    Dealer
    Anderson Toyota
    50,997
    Repair Order Number: 0077332
    48,750 MILE SERVICE
    VIEW DETAILS
    4/28/05
    Dealer
    Anderson Toyota
    46,968
    Repair Order Number: 0070342
    45,000 MILE SERVICE
    VIEW DETAILS
    DOWNLOAD DETAILS
  17. m.wynn
    684
    1,229
    Queensbury, NY
    4/19/17
    Dealer
    Northbrook Toyota
    162,152
    VIEW DETAILS
    12/15/16
    Dealer
    Anderson Toyota
    157,643
    VIEW DETAILS
    2/20/16
    Dealer
    Anderson Toyota
    144,325
    VIEW DETAILS
    12/26/14
    Dealer
    Anderson Toyota
    133,498
    VIEW DETAILS
    6/12/14
    Dealer
    Smart Toyota
    129,365
    VIEW DETAILS
    11/26/13
    Dealer
    Anderson Toyota
    128,023
    VIEW DETAILS
    9/29/11
    Dealer
    Anderson Toyota
    107,038
    VIEW DETAILS
    5/5/09
    Dealer
    Anderson Toyota
    82,946
    VIEW DETAILS
    11/6/08
    Dealer
    Anderson Toyota
    79,336
    VIEW DETAILS
    8/5/08
    Dealer
    Anderson Toyota
    77,541
    VIEW DETAILS
    3/26/08
    Dealer
    Anderson Toyota
    74,703
    75,000 MILE SERVICE
    VIEW DETAILS
    11/8/07
    Dealer
    Anderson Toyota
    72,141
    VIEW DETAILS
    5/31/07
    Dealer
    Anderson Toyota
    68,386
    VIEW DETAILS
    1/25/07
    Dealer
    Anderson Toyota
    64,780
    67,500 MILE SERVICE
    VIEW DETAILS
    12/12/06
    Dealer
    Anderson Toyota
    63,752
    VIEW DETAILS
    8/31/06
    Dealer
    Anderson Toyota
    60,467
    RECALLS
    VIEW DETAILS
    6/15/06
    Dealer
    Anderson Toyota
    58,573
    60,000 MILE SERVICE
    VIEW DETAILS
    1/19/06
    Dealer
    Anderson Toyota
    54,580
    VIEW DETAILS
    9/8/05
    Dealer
    Anderson Toyota
    50,997
    48,750 MILE SERVICE
    VIEW DETAILS
    4/28/05
    Dealer
    Anderson Toyota
    46,968
    45,000 MILE SERVICE
    VIEW DETAILS
    DOWNLOAD DETAILS
  18. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Service records suggest that until a couple of years ago, it was in Havasu, AZ. That explains the condition, no snow, no salt, no rust Last entry says Northbrook Il. So it's probably out of my neighborhood, That is a very nice hulk, tho. Wish it was closer, I'd go mine parts to keep other Prius's alive.
  19. Spaced_Rat
    Spaced_Rat New Member
    29
    Hood River, Oregon
    2001 Prius
    I
    Want to get me some minty interior parts from that minty 1st Gen? I need the rear trunk lid carpet and the map light.
  20. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    According to NADA, retail value on an '01 Prius with 162k is $2500. What's it worth if it needs a new $2500 battery?
    Zero!
  21. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Voodoo economics! If you put $2500 in to a car that's worth nothing, and it extends the life of a nice car, it's worth at least $2500. It's a desert car, no rust and probably will need a inverter pump and maybe a brake booster pump (used of course) within the next 50k miles. I'd probably have fixed it.
