how do you remove the airbag on gen4 prime????
Discussion in 'Prime Main Forum (2017-2022)' started by Dillster, Oct 26, 2018.
  1. Dillster
    Dillster New Member
    Suffolk Va.
    Can anyone help with the removal of the airbag on the drivers side. Trying to remove the airbag to access the white toilet bowl plastic under it to be painted. there is no info on this any were that I have found. Thanks!
  2. schja01
    schja01 Senior Member
    1,815
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    Why paint? I obtained one of these.
    https://ebay.to/2Oahl6u
    About a minute to peal off the protective tape and place it over the white plastic.
    Easy peasy.
    J
  3. Dillster
    Dillster New Member
    Suffolk Va.
    Yeh I see those all the time but it drives me nuts when I can't find the info for a simple job. I want to paint match the whole thing not just the bottom. Its my OCD that drives me to do things the hard way(y)
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    The reason you can't find instructions is:
    That is a DANGEROUS piece of equipment......one wrong move and you can be DEAD. :eek:
    And then if you don't get it back in exactly right and there is an accident.......you could be DEAD again.
    The warning about getting a professional to service it is made for a VERY good reason.
    Try not to let your vanity put you in the hospital.......or worse.
    Learning to live with things that you don't exactly "like" is a good skill to have.
  5. Dillster
    Dillster New Member
    Suffolk Va.
    Good point! Thanks for the concern for a fellow Toyota driver!
  6. Mendel Leisk
    40,492
    This reminds me of the time I was going to tension the torsion spring on our garage door. I got it wound up two or three turns, then started sweating, backed off, got the pros.
    alexcue likes this.
