1. Mohamed tahhan
    Mohamed tahhan New Member
    Wijlre
    20181025_120845.jpg 20181025_120839.jpg I see this alarm on my prius today and it didn't work any more.
    What can I do?
  2. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Replace the HV pack, most likely.
    Mohamed tahhan likes this.
  3. bisco
    51,524
    welcome!
    check the oil level, check the inverter fluid reservoir for movement in the fluid when in ready, read the trouble codes with a prius aware scanner. how many km on her?
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The big red triangle means the car has a code. A good OnBoard Diagnostic scanner will tell which code was set.
    They tend to have the format ANNNN Where A is a Letter and N is a Number in Hexadecimal from 0 to F.
    If your mechanic gives you the code it is easy to look them up online to confirm their diagnosis. So a P0A80 may mean you need a new HV Battery. (sometimes there are detailed sub codes that can help more.
    #4 JimboPalmer, Oct 25, 2018
    jerrymildred and Mohamed tahhan like this.
  5. bisco
    51,524
    thanks jumbo!
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,516
    Bay Area, California
    2019 Prius Prime
    Jumbo:oops:?
    But maybe the shoe fits :whistle:?
    edthefox5 and bisco like this.
  7. Mendel Leisk
    40,974
    Retribution for being called bisto?
    bisco and Raytheeagle like this.
  8. Raytheeagle
    11,265
    15,516
    2019 Prius Prime
    I always like when he takes on his brash alter ego: @brisco :).
    bisco and Mendel Leisk like this.
  9. bisco
    51,524
  10. RRxing
    RRxing Senior Member
    2,537
    1,810
    NEPA
    The Cisco Kid was a friend of mine...
  11. Mohamed tahhan
    Wijlre
    I changed the 12v battery but the problem is still
  12. Mohamed tahhan
    Wijlre
    I can't check the inverter fluid reservoir for movement because it didn't go on ready
  13. bisco
    51,524
    codes, unfortunately
  14. bisco
    51,524
    have you checked all the fuses? prius has a lot, and a number of high voltage ones.
  15. bisco
    51,524
    how many km on her?
  16. Mohamed tahhan
    Wijlre
    No not yet
  17. Mohamed tahhan
    Wijlre
  18. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    HOW TO CHECK INVERTER PUMP:
    1) Prop open engine hood.
    2) Open inverter reservoir (that opaque coolant container, next to the big square silver thing in the middle of the engine compartment).
    3) Visually look inside the inverter reservoir. NOTE the calmness of the coolant inside this reservoir.
    4) Make the car IG-ON or READY.
    5) Visually look inside the inverter reservoir again. Do you see fluid movement? It should have a flow rate like a calm tranquil stream.
    6) If it is quiet enough, you may even hear the inverter pump; its sounds like an aquarium air pump.
    7) DO YOU SEE FLUID MOVEMENT in the inverter reservoir? Do you hear the inverter pump? If yes (fluid movement), Inverter pump is GOOD. If NO (fluid movement), inverter pump is bad and needs to be replaced.
    A failed inverter pump will produce different symptoms (ie A/C shutting off) and the same warning icon
    ( [​IMG] ) on the MFD (Multi-Function Display) in the top left corner, when the inverter begins to overheat.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Turtle car icon in mfd is usually bad hybrid battery especially with the battery meter empty.
    New hybrid battery time,
