have to gush a little... and a question or two
Discussion in 'Gen 2 Prius Main Forum' started by ramarren, Aug 14, 2006.
  1. bps
    bps Active Member
    304
    119
    <div class='quotetop'>QUOTE(Godfrey DiGiorgi @ Aug 15 2006, 06:01 PM) [snapback]303786[/snapback]</div>
    Same here! Even though I'm sure it's useful to some, and fun for others, I always have a good sense of direction and could not justify the $1,850 cost. But for some, it's more than worth it.
    Bryan
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I give the lower tire pressure six months, max. As you get sucked
    into the numbers game, you'll want them right back up at 44/42 where
    they belong, and be happily coasting like a bicycle.
    _H*
  3. ramarren
    ramarren New Member
    96
    San Francisco Bay Area, California
    <div class='quotetop'>QUOTE(jbarnhart @ Aug 15 2006, 11:15 AM) [snapback]303611[/snapback]</div>
    Fiend!
    I ordered the BT Brace today. Tomorrow morning I go to the dealer and they'll do the alignment correction. I took it back and forth to San Leandro again today and noticed that with the re-set tire pressures the steering feel is better but it still wanders more than it ought to. I know that something is not aligned correctly.
    I've got 250 miles on it now and the gauge reads just barely down half a tank. Economy screen says 45.8 mpg. I'm going to like this a lot. By now, the Land Rover would have consumed a near-$40 tank of fuel. And the Prius is MUCH quieter and more comfortable to boot.
    Life is darn good.
    Godfrey
    Current work on display: "A Traveler In London" www.gdgphoto.com/traveler
  4. ramarren
    ramarren New Member
    96
    For closure on the steering wheel/wander issue:
    I dropped the car off this morning at 7. Picked it up at 1pm and took it for a 25 mile ride on an errand. Steering wheel is oriented correctly and the inclination to wander a bit is gone. When I asked the service writer what they'd found, he said the toe in was found to be off the spec ... exactly what I suspected.
    Life is good.
    Godfrey
