Options for Broken Rear Garnish Fasteners?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by acadiaphile, Apr 17, 2016.
  1. SteveZ
    SteveZ Junior Member
    Santa Fe, NM
    I had only one bolt and the two plastic pins holding my garnish onto the vehicle - the plastic holding the other three bolts had snapped off. I can vouch for the strength of JB Weld to repair this. I used KwikWeld (sets in 6 minutes, cures in 4-6 hours) to initially secure the broken plastic pieces, then a generous amount of regular JB Weld (sets in 4-6 hours, cures in 15-24 hours) to reinforce and also bond the screws to the plastic. The garnish mounted rock-solid, and I didn't have to waste money on a replacement garnish at an inflated price. Thanks for the writeup!
  2. a_gray_prius
    2,927
    783
    IL
    I just found this thread and recently encountered the same issue. Your assertion unfairly places blame on the owner - my garnish piece broke in a single lift of the hatch. There was no looseness to the part prior to lifting - and before you attempt to place blame for putting too much strain on the garnish instead of the hatch release, it should be noted that this was in the course of lifting the hatch using the hatch release (which bent).
    Stevewoods likes this.
  3. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
    Can't really argue with you on that....I know that everytime I lift the hatch, I take a deep breath and say a little prayer. :whistle:
    Raytheeagle likes this.
  4. Mendel Leisk
    41,329
    Using one of the previous 2-part epoxy repair pictures: I would advocate to put a second coat of epoxy over the joint, extening further. That extra skin reinforces things I think:
    This is the stuff I picked up recently, basically a lifetime supply. Not sure how it compares to JB Weld, it's more-or-less clear, generous size bottles, easy to work with:
  5. Mr. Treadwell
    Mr. Treadwell New Member
    I ended up eventually drilling extra bolt holes through the door itself to provide extra anchoring around the cracked off mounting points of the plastic clips.
    Not the prettiest of solutions - but the only visible damage is to the garnish itself (a few visible bolts). I had tried a few different adhesive solutions previously with no luck.
    On a particularly cold day the garnish just came to pieces - and seems pretty much a silly thing to try and continue to repair.
    I've seen replacement kits with an extra metal backing piece. Thinking of trying this next. Anyone tried it - and how did it go?
    Torquewrench likes this.
  6. 1s2k
    1s2k Junior Member
    Anyone replace their rear garnish recently? I'm about to order one from eBay that includes a metal reinforcement.
    Also, what's the recommended procedure to remove and reinstall the Toyota emblem?
