Battery Vent Tube Questions
Discussion in 'Gen 2 Prius Main Forum' started by davecook89t, Nov 5, 2018.
Tags:
  1. davecook89t
    davecook89t Senior Member
    1,076
    812
    Washington State, Florida
    Four Touring
    I read through all 50 questions and answers on this battery on Amazon. There were a few people that claimed it was vented. The best was a question as to whether it was necessary to drill out the hole. There were 3 answers: Yes, Maybe and No.:ROFLMAO:
  2. cyberpriusII
    1,153
    1,727
    Mars Hotel
    It's why I spend the cash on the Toyota.
    Raytheeagle and davecook89t like this.
  3. davecook89t
    1,076
    812
    Four Touring
    In retrospect, that's what I should have done. Being new to hybrids at the time, I thought I could just go to an auto supply store and buy one. The first surprise was that none of the first few auto stores I called even stocked the Prius battery. Then when I found one at a Lordco store in Burnaby, BC, it was something like $280 Canadian (can't remember the exact amount, it was a couple of years ago). I should have gone to the dealer at that point, but was not in the habit of buying any type of accessories from a dealer, I just thought (perhaps accurately) that they would be even more expensive.
  4. cyberpriusII
    1,153
    1,727
    Mars Hotel
    Aye, I understand the issue with dealers. But, sometimes it just makes sense.
    This past summer we tried to cheap out with a new (aftermarket) ignition switch as well as a new aftermarket blower motor resistor -- both from NAPA and both respected (more or less) aftermarket brands for our Camry.
    And, while more often than not, that works fine, sometimes it does not. We ended up having to get the Toyota parts after real installation hassles. It would have much less trying if we had gone to the dealer in the first place.
    Having said that, I am the first in line to try to save money on an aftermarket part, but just depends on the part...Cabin filter, wiper blades, etc. fine......A battery that has quirky fit requirements -- dealer...
    kris.
    davecook89t likes this.
  5. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    One thing I would never do is drill into a battery like that. :)
    davecook89t and cyberpriusII like this.
  6. cyberpriusII
    1,153
    1,727
    Mars Hotel
    :eek::eek::eek::eek::eek::eek:
  7. PriusCamper
    PriusCamper Senior Member
    12,337
    5,012
    Pacific Northwest, USA
  8. davecook89t
    1,076
    812
    Four Touring
    I was not planning to. I'm not sure what shards of plastic inside the battery would do to it. I'm still hoping someone will tell me the plastic wall inside the battery that my tube is pressed up against is perforated and will pop out if the pressure becomes too great.;) I guess not. I can't believe a reputable GM-affiliated company would place a fake hole in the side of their battery to deceive the unsophisticated. That seems too devious even for them.
  9. Skibob
    2,912
    1,502
    Northern California
    The factory write says the battery is pressurized. It would be bad to drill that out and release the pressure.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Holy jeez we are beating this to death. Davecook....pm me your address. I will mail you a complete vent tube/elbow assembly. I have a couple in the shop, as I have a habit of picking up odds and ends from salvage cars.
    m.wynn, SFO, Raytheeagle and 2 others like this.
  11. PriusCamper
    12,337
    5,012
    I think it's a safe assumption that the battery vent tube seal is not fake, but made of a much thinner plastic so it's the first point to fail if pressure builds up. Of course with the NiMH batteries in the Prius pack I've seen way too many cells that blow their plastic tops off rather than vent the pressure out the hole, so there's that.
  12. davecook89t
    1,076
    812
    Four Touring
    That's what I was hoping to hear. Thanks.
  13. davecook89t
    1,076
    812
    Four Touring
    Done.
  14. Skibob
    2,912
    1,502
    Northern California
    That’s a good idea. Some of the photos show the vent tube installed, why take a chance. I wonder what happened to your old one?
  15. davecook89t
    1,076
    812
    Four Touring
    Good question. The grommet had a hole in it, like a donut. I doubt the shop that installed my battery would have thrown it away, especially since there is an obvious hole for the vent tube in the new battery. Perhaps the original battery had already been replaced with a non-vented one when I got the car.
  16. Skibob
    2,912
    1,502
    Northern California
    Do they even make a non vented one? Personally if I were to change my battery and I got a non vented one I would just leave the tube there. It’s not like it’s hurting anything.
  17. TMR-JWAP
    6,404
    6,088
    Columbia, SC
    One vent tube, will be enroute in the A.M.
    May need a little cleaning.
  18. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,516
    Bay Area, California
    2019 Prius Prime
    Thanks for helping and achieving resolution (y).
    m.wynn, SFO and davecook89t like this.
  19. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Did anyone tell him to put an oil catch can on that battery yet?
  20. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    YES. Most ALL AGM batteries are sealed and non-vented......with an emergency pressure relief valve.
    IF.....you get into a situation where that valve releases, whether or not you have a "vent tube" on it is probably of little or no consequence.
    INSTALL THE BATTERY AND DON'T WORRY ABOUT IT.
    or keep obsessing unnecessarily.
