2005 G2 230K Miles, Block #6 Discharge issue
Discussion in 'Gen 2 Prius Technical Discussion' started by James1964, Nov 5, 2018.
  1. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Please advise. Thank you!
    From Dr Prius diagnostic test with hard acceleration, hard brake.
  2. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
  3. bisco
    50,803
    i'm no expert, but it sounds like you need some balancing. have you considered pro long?
    James1964 likes this.
  4. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    I have heard of it but not tried it yet. I'll look for a Seattle provider.
  5. Hybrid Battery Exchange
    67
    86
    Portland, OR
    If it's the original battery then you have a weak module in block #6, it has diminished capacity. Can you post more information from Dr Hybrid, like actual voltages under load/charge?
    SFO and bisco like this.
  6. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    I will attempt to do so.
  7. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    I'm cautious about saying that this is a fairly new, warranted Dorman for fear of being stoned by the purists. It's charging fully and getting 48mpg. My mechanic said that Dr Prius, or any other app based diagnostic tool isn't to be trusted. It tested all clear on this same app a few months back though.
  8. bisco
    50,803
    I think you can get some valuable info as hybrid battery exchange suggests above. Knowing your block voltages under load wil be very enlightening
  9. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    The app isn't easy to pull information from but I will try. Maybe I get a tech stream data pull at a hybrid shop and see if they do the prolong service. How often is that useful to do, the balancing thing? Thanks btw
  10. Hybrid Battery Exchange
    67
    86
    Portland, OR
    The app shows block voltages, the rest is up to you. With the car in Ready mode, put the gear selector in neutral, a/c on, watch the voltages as they fall. Let the battery discharge down to 14.5v per block, keeping an eye on #6. If it all of a sudden it falls by a 1.1-1.3 volts immediately stop the test, you have a bad cell within a module. Put the car back in P and let it recharge the hybrid battery.
    Reconditioning is something that will make a healthy battery perform better, it will not fix a failing cell. On my bench reconditioning a battery with a weak cell just makes the failure show up at higher pack voltage.
    #10 Hybrid Battery Exchange, Nov 5, 2018
  11. Hybrid Battery Exchange
    67
    86
    Portland, OR
    Dr Prius and Hybrid Assistant monitor all 14 block voltages and plot/log them and compare the differences between them. This difference between blocks at various states of charge as well as overall pack capacity is the determining factor of how healthy a battery is, not the opinion of a mechanic who fails to understand how to properly asses a battery.
    The only part in question with Dr Prius is what is their tolerance in specifying "poor balance block", this is why we are asking for real numbers.
  12. bisco
    50,803
    If the pack is under warranty, your best bet might be to wait for failure
    Check the dorman warranty to make sure opening the pack doesn’t void it
  13. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    I did a recording of the battery monitoring but can't figure out how to share. Failure would be a bummer but I hear you. It's the most meaningful indicator.
  14. bisco
    50,803
    It’s usually the only indicator that will trigger warranty. You get the code, but should still be able to drive it
  15. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    So far no codes or red triangles so we'll keep driving her. HV battery charges to full and rarely goes below 3-4 bars so hopefully it doesn't crap out too soon.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,262
    15,506
    Bay Area, California
    2019 Prius Prime
    @biglew8 has a thread here where a lot of folks have described their experience with Prolong, including me;).
    He’s also a Seattle local(y).
    SFO and James1964 like this.
  17. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Awesome! Thanks!!
    Raytheeagle likes this.
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Good luck on the pack. I wish you many miles on the Dorman. If you don't junk the car when it fails, you may want to look into new cells for replacement versus buying someone else's old used cells...
  19. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    We bought it with the Dorman already installed. We'll see. It's a great car for my son so we'll probably keep it alive and def install new cells when it comes to that-
  20. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Thanks for the guidance. I wasn't able to share the live data from DP app unfortunately. I did the driving test a few times and it called out block #6 every time. Seems there isn't much to do about this until the unit fails completely but I may look at getting her some prolong therapy.
