12v battery voltage?
Discussion in 'Gen 4 Prius Technical Discussion' started by rosencrantz, Nov 9, 2018.
  1. bisco
    51,024
    could be, but i doubt they know any more about batteries than their machine tells them
    rosencrantz likes this.
  2. Mendel Leisk
    40,467
    Quite a difference between your voltage reading and theirs. The one reason I can see: a freshly driven car has a bit of "surface charge": it reads high, and with an overnight sit that reading'll drop.
    Still, if the Pep Boys measured "health" (cranking amps measured vs rated) is good, maybe all it needs is a good charge session. CTEK Multi US 4.3 is my current charger, can't fault it. I've wired in the quick connect, since I'm a frequent flyer, lol.
    The Solar BA5 has one verdict which is "good but needs recharge".
    kithmo, rosencrantz and bisco like this.
  3. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Interestingly, I think the 12v on my current Prius is physically larger than what was in my 2013. My memory could be off a bit though.
  4. bisco
    51,024
    i think it may be as well. that should help, i would think
  5. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    I had a similar thought regarding a freshly driven car. Wouldn’t a properly functioning charging system normally charge the 12v up to full given some time and miles?
  6. Mendel Leisk
    40,467
    The car's charging system is good for a battery in good health. But for one that's been partially depleted, either by protracted sitting, or something like a door left open overnight, then a charger is likely needed.
    You gotta have all this stuff, lol. Unless you're bisco... :cool:
    kithmo, bisco and rosencrantz like this.
  7. Mendel Leisk
    40,467
    Checked ours this morning, just the voltage. It's a bit of a pain using the Solar: it needs to be connected right at the posts, which means around back, take the hatch floor and tray out, and so on. So, just the voltage, the car had a good drive yesterday, sat overnight, ambient temp is 4C. This is an Optima Yellow Top, a bit over 3 years post install. They tend to read a bit higher voltage than conventional, so for what it's worth:
    (Connecting at the CTEK quick-connect adapter.)
    alanclarkeau likes this.
  8. bisco
    51,024
    prius charging is very slow. iirc, about 8 hours to charge the 12v. not sure what level that is from though.
  9. Mendel Leisk
    40,467
    Full disclosure: I do keep that sucker on life support, every day the car's not driven (which is often), it's hooked up to my automatic charger. Interesting longevity experiment, I get the sense it's protracted non-running time, multiple days, that ages batteries, what with the constant "background" drain.
    And again, topped-up AGM's tend to have a bit higher voltage than conventional.
    Andyprius1 and alanclarkeau like this.
  10. bisco
    51,024
    do you have a second vehicle, or rarely go anywhere?
  11. Mendel Leisk
    40,467
    #2. Dear wife drives more'n me. :oops:
    alanclarkeau and bisco like this.
  12. bisco
    51,024
    i don't either. but we do drive 8 miles every morning to go for a walk. after that, she takes the pip for anything within ev range, or else the hycam
    Mendel Leisk and alanclarkeau like this.
  13. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Thanks for taking the time to measure your Optima. I had an optima in my 2013 and, as you mentioned, I think they tend to read a bit higher than normal. I have an automatic 1.5 amp battery maintainer/charger that I normally use for the jet ski batteries. I clipped that charger onto the Prius battery this morning....I’ll give it the day and see how it looks. As I’m writing this, I took a look and the charger says “charged”. This after two hours on the trickle charge. Maybe I’m good to go?
  14. Mendel Leisk
    40,467
    Recheck the voltage in a day or two, after it's sat overnight, that should scrub off any "surface" charge. Hopefully you're out of the woods.
  15. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    One can hope! Thanks again for your advice. I’ve certainly learned a lot reading through Priuschat.
  16. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    THANK YOU, This video on Utube is extremely good. We now have a simple way of checking 12 Volt health and the converter outputs . In addition I found out that the 12 Battery is a lead acid battery capable of putting out 100 amperes of current. He also mentioned that the 12 Volt battery was responsible for MOST of the Primes operation. We always suspected this was the case, BUT, now we have proof. Thank You Professor John Kelly!
    I urge everybody to watch this video!
    #56 Andyprius1, Jan 13, 2019
  17. Andyprius1
    2,327
    859
    Cool CA
    This not only indicates the health of your 12 Volt, but proves that the converter is also doing its job.
  18. Mendel Leisk
    40,467
    The implication being that activation of the brake pressurizing system is going to alter the voltage? I would do an A/B test of that, suspect it doesn't make much difference.
  19. bisco
    51,024
    thanks, please let us know the results!:p
    #59 bisco, Jan 13, 2019
  20. Andyprius1
    2,327
    859
    Cool CA
    Professor Kelly demos that any and all loads can be monitored and estimated by doing this simple Voltage and converter check. No more guesswork, no more theories based on thin air. For example: Since 2005 we have been discussing what the 12V battery should read ? Many said, if its only 12V its bad. Others said if its only 12.2 its going bad, better buy a new one. All conjecture, nothing ever factual in any opinion. Nobody ever bought up maintaining proper voltage levels and current draws Or the converter and its role. Well now that's all over. Prof Kelly backed all information up with the Toyota Manual Procedures.
    #60 Andyprius1, Jan 13, 2019
