Antifreeze? West to east coast move
Discussion in 'Gen 3 Prius Main Forum' started by motifone, Nov 15, 2018.
  1. motifone
    motifone Junior Member
    48
    Hi all
    Recently moved my 2012 Prius from the west coat to east coat. I'm pretty sure most standard coolants include an antifreeze, yes? Or, would my Prius require anything additional or stronger now that it has moved to the lower temps back east? I've always had it maintained out in California and asked one of the California service guys if he'd thought I'd be okay with my existing coolant, but he wasn't 100% sure. Thought I'd ask here before I bring it to a local shop. Thanks all!
  2. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
    »» The water freezes at 0 degrees centigrade.
    Antifreeze can lower the temperature to around 30 under zeros and not freeze. What facilitates the ignition. If you are in a place where the temperature reaches 0 degrees or less I recommend using antifreeze
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Prodigyplace likes this.
  4. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Beside the obvious use, Antifreeze also contains corrosion inhibitors which are very useful in any climate. A tester is less than $3.
    Robert Holt and jerrymildred like this.
  5. ASRDogman
    ASRDogman Senior Member
    7,420
    3,863
    Where on the east coast? In Florida, 50/50 mix works all year round. If you are in Maine, you'd have to check the owners
    manual, I believe it calls for more coolant than water, but since I don't have the manual in front of me and too lazy to go look,
    can't say for sure. :)
  6. bisco
    51,518
    if you are using toyota coolant, you're covered
    sorry to hear about your move to the least coast.(least natural disasters)
    Mendel Leisk and m.wynn like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    Easy. Ask a shop in your new area to test it.
    At 6 years old, it probably could stand to be replaced anyway.
    If you do that, do NOT buy into the scam of paying extra for a "flush".
    Grit likes this.
  8. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Chemistry Lesson:
    Any solute in a solvent will both lower the freezing point of that solvent and raise its boiling point. So, by having coolant (which has particles dissolved in it so that its boiling point is higher than water by itself), you automatically have antifreeze. The more particles dissolved per volume solvent, the higher the boiling point will be raised/lower the freezing point will be reduced.
    If you're moving somewhere with extreme cold in the winter, you might want to adjust the mix. It's been a while since I've looked at a coolant bottle, but they used to have charts showing the mixing ratio with water for desired temperature performance.
    douglasjre and Grit like this.
  9. Mendel Leisk
    40,966
    The stock coolant is 50/50 mix in the states, which is fine.
    bisco and Raytheeagle like this.
  10. motifone
    48
    Thanks, all. We are in Boston. I've always had the Toyota dealership add the coolant, so based on some of these replies, I believe I am fine. If unsure, I will take it to a shop or buy the cheapo tester from online. I also would like to check my wife's Crosstrek (also brought from California), so maybe the testing tool is the quickest route.
    Robert Holt and bisco like this.
  11. bisco
    51,518
    hope you're enjoying the snow:unsure:
  12. Mendel Leisk
    40,966
    Toyota Canada has 55% pre-mix coolant. I wonder if some places in the States also get this, say Alaska and the north central States. Either way you'll be fine.
    One thing that's always puzzled me: why don't the coolant testers show percent, not freeze protection? I think they're pretty much pointless: if all that's ever gone into your system is 50/50 premix, that's what you've got.
  13. hill
    8,726
    the poor southern states deserve some love to. Consider certain cities of various Southern States' low temps on one occasion or more;
    Alabama 1966 - 27°f
    Georgia 1940 - 17f
    Cali 1937 -
    Arizona 1971 - 40f
    Texas 1933 - 23f
    New Mexico 1951 - 50f
    California 1937 - 45f
    I get severe shrinkage just thinking about those kind of temperatures
    ok sure - it's not most of their cities nor most of their years, but show the southern peeps some love with a nice hot toddy. Even folks that don't regularly see freezing temps can use a good stiff shot of antifreeze because we travel. You hit the mountains or travel to Frosty places for vacation and if you don't have it in your radiator, next morning, you may very well wish you did.
  14. Prodigyplace
    12,462
    11,703
    Central Virginia
    To be complete you need to show the highs too. Coolant changes the boiling point too. ;)
    hill and Robert Holt like this.
  15. Mendel Leisk
    40,966
    Toyota only sells the (specified) "super long life coolant" pre-mixed? So how would you make any adjustment, short of switching to an alternate coolant that is available un-mixed? They have another coolant, that's not rated as long a life, but does come in concentrate, I think.
  16. Grit
    Grit Senior Member
    6,568
    4,223
    Wilkes Land
    o_O
