Problems with key reprogram
Discussion in 'Gen 2 Prius Main Forum' started by Dezfreeze, Nov 17, 2018.
  1. Dezfreeze
    Dezfreeze New Member
    NC
    Hi- 2004 Prius- non-SKS. I’ve reprogrammed a key on this car before without problems. Wife lost the extra... I still have 1 good working fob- does it all ok. So- I can get the new key reprogrammed to lock/unlock the doors, but will not start the car. I’ve tried with a new OEM key from eBay after purchasing a 3rd party new key off Amazon and returning it. I think my car is the problem. The car goes into ‘reprogram mode’ with the solid lit immobilized light- but when I put the new key in the slot to reprogram- it gives me 2 quick blinks followed by 3 quick blinks of the light. It does that for about a minute- then goes back to regular flashing. It never stops flashing entirely and never programs the new key. Any help?
  2. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    Your car might be at the limit of allowing 5 keys to start the car. Techstream can be used to clear out lost keys and make room for new.
    Programming a fob to open doors changes the fob and not the car so is not subject to the five fob limit.
    Skibob likes this.
  3. Dezfreeze
    NC
    Yes, that could be it. I had read about the 5 key limit, but assumed the lock/unlock success meant I was still under that #.
  4. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Just make sure when you are deleting keys you don’t delete the one that works. That would be bad.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    From what I have read, TS can add from zero, but yes it is best not to remove currently working keys.
  6. Skibob
    2,912
    1,502
    Northern California
    Looked a little scary when I was in there in Techstream. If he sees 5 key codes then he will have to figure out the working one. I think it tells you what one is in the ignition slot if I recall.
