Where the windshield meets the dash
Discussion in 'Gen 2 Prius Main Forum' started by Proco, Aug 17, 2006.
  1. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    As I was driving in to work today I noticed a black styro/foam rubber type strip popping up where the windshield & dash come together. It doesn't appear to go all the way across the dash. It's only on the driver's side. I ran my finger along the passenger side & couldn't feel anything.
    Is this some kind of cushioning that's coming loose? Or is it just something my dealer forgot to remove before I picked up the car?
    I've had the car a little over 6 weeks and I just noticed this. I'd post pictures, but I don't have a digital camera.
    Thanks!
    Mike
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I think those are one of the packing items the dealer neglected to remove. I vaguely remember taking something like that out of my Prius when I picked it up.
  3. Proco
    Proco Senior Member
    2,570
    172
    28
    <div class='quotetop'>QUOTE(Presto @ Aug 17 2006, 10:00 AM) [snapback]304622[/snapback]</div>
    Given the history I have with this particular dealer, I've been leaning that direction myself. I just want to make sure I don't remove something that actually belongs there.
    I recently removed two little clear plastic triangles over the corner of the plastic where the dash meets the little side windows.
  4. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(Proco @ Aug 17 2006, 10:11 AM) [snapback]304629[/snapback]</div>
    I have those little plastic triangles too...everytime I see them I think I will cut them out the next time I am near a pair of scissors but then I forget... :rolleyes:
  5. Proco
    Proco Senior Member
    2,570
    172
    28
    <div class='quotetop'>QUOTE(Renocat @ Aug 17 2006, 10:13 AM) [snapback]304631[/snapback]</div>
    To get them out I worked a finger underneath each one and gripped it with a finger from the other hand (the angle made it tough to use the same hand). Then I just started working them up. The plastic by the little window popped up a little bit and the clear covers slid off. Then a little push to pop the plastic back into place.
  6. Presto
    1,326
    24
    Vancouver, BC
    EDIT: wow.. double post sorry
  7. cattail722
    cattail722 cattail722
    47
    Bay Area, California
    I have the same thing in my car, driver side as well. I keep thinking I can push it down one day and keep forgetting....maybe it comes out instead?
  8. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(Renocat @ Aug 17 2006, 09:13 AM) [snapback]304631[/snapback]</div>
    Yeah, you can remove those.
    BE CAREFUL!
    The plastic scratches easily. And there's no need to cut. They are not attached, just folded over. Wiggle something soft but stiff behind and work them out (and keep the dirty jokes to yourself). :D
    I removed mine because I was concerned that the plastic over the plastic in the sun would cause fading variances.
