EV Percentage Remaining Display
Discussion in 'Prime Fuel Economy & EV Range' started by Barry in PA, Nov 28, 2018.
  1. Barry in PA
    Barry in PA New Member
    PA
    2018 Prius Prime
    I purchased a 2018 Prime 2 weeks ago, and the multi-info display showed the remaining charge available in percent. Last 2 days that display is missing, perhaps we accidentally hit something that removed it. Tried following the manual, EV display in Settings is set to percentage. Dealership can't help, so looking for suggestions. Thanks.
  2. schja01
    schja01 Senior Member
    1,815
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    The easiest way to inadvertently change it is pressing the TRIP button on the steering wheel. Press it repeatedly and see if one of the displays is what you want.
  3. Barry in PA
    PA
    2018 Prius Prime
    Tha
    Thanks, but the EV screen on the Trip display only shows estimated miles remaining on the charge, not the percentage.
  4. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    So I found this on page 215 of the Owner’s Manual and it says you can change miles/percent through Meter Customization. Sorry about the poor copy and paste. The nice pictures from the Owner’s Manual did not make it.
    One of the following 2 information in the items of “HV System Indi- cator” in “Meter Customize” settings can be selected to display in the left upper corner of the Hybrid System Indicator. (→P. 233)
     “EV Distance”
    The approximate distance that can be driven using only the electric motor (traction motor). (→P. 100)
    When the air conditioning sys- tem is operating, the icon dis-
    play changes to and the driving range with the air condi- tioning system on is displayed.
     “EV Energy”
    The percentage of the remain- ing hybrid battery (traction bat- tery) that can be used for EV driving is displayed.
    Becomes 100% when the hybrid battery (traction battery) is fully charged.
