Need new rims for winter,but no idea what im doing
Discussion in 'Prime Accessories and Modifications' started by Travis64, Nov 26, 2018.
  1. Travis64
    Travis64 Member
    Ny
  2. toyopri808
    toyopri808 Active Member
    226
    116
    Travis64 likes this.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Yep, get toyopri808's suggestion, they'll work fine.
    Also buy from Discount Tire if they're local to you because when you re-mount your stock wheels & tires Discount will
    re-set your TPMS for free very quickly if needed.
    Rob43
  4. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  5. Travis64
    Travis64 Member
    Ny
  6. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    The .5" won't* effect anything. That Michelin is great.... but if your buying at that price point consider the Bridgestone Blizzak WS80 because they're fractionally better & are "H" speed rated vs "T"
    The WS80 has a $70 dollar rebate currently.
    Rob43
    * Unless you're racing....
  7. Travis64
    Travis64 Member
    Ny
    Yes you are right with $70 rebate it is a better deal.
    Thank you!
    I dont need to buy valve stems if i am buying rims and tires right?
  8. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    You're welcome.
    You will need some form of valve stems for your new purchase, you can either buy the cheap black rubber stems (that's what I'd do) or you can invest in TPMS valve stems at a Much Higher price point. I personally just live with the dash Tire warning light that blinks for roughly ~1 minute for the ~3 months that I'll have my snows mounted for.
    Rob43
  9. Mendel Leisk
    40,260
    This is a Toyota Corolla steel rim that's 100% compatible, correct (not oversized) hub opening. I picked up a set new in fall of 2010, for $70 apiece:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
  10. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    In the summer on dry pavement, a wide tire and wheel can offer more traction.
    In the winter, in rain and snow, a narrow tire and wheel can cut through to the pavement at times the wider tire will 'float', for better traction.
    Do not reduce tire size beyond the weight of the vehicle. I would not fear 185s instead of 195s, but smaller might not survive a full load.
    Here is the data for the X-Ice Xi3
    So with 185s, you can carry 528 fewer pounds of weight. (1521 - 1389) * 4 = 528
  11. Travis64
    Travis64 Member
    Ny
    Thanks to you guys for the help,took 2.5 half weeks to get them.
    Here are some pics
    Had about 2in snow 1st day and i put the pedal to the floor no spin
  12. Mendel Leisk
    40,260
    Judging from the pics the snow was just starting to fly. (y)
    If they're Corolla rims a 2" abs end cap (hardware store item) can serve as a center cap, if you first push on something like a bicycle inner tube section (say 3/16" wide). Stretch it onto the raised flange, then tap the center cap on. It'll keep it from rusting.
    If they're aftermarket steel rims they're very likely oversized hub openings and no raised flange, then maybe just apply a little oil: a drop or two and brush it around. Sparingly, because due to centrifugal forces it'll migrate outwards from the center. Or the bees-knees: boiled linseed oil.
  13. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Congrats & good timing.
    What snow tires did you go with ?
    Rob43
  14. Travis64
    Travis64 Member
    Ny
    I got the blizaks :)
  15. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Great choice...
    Give us an update when you get a big-ish snowstorm (6+ inches) on how well your Prime/Blizaks cope with the storm.
    Rob43
  16. Travis64
    Travis64 Member
    Ny
    F806FE5F-AC4B-4755-A239-886D726621F3.jpeg Got a new 2018 and put the blizzaks on.about 4-5in yesterday no slippage =]
  17. Mendel Leisk
    40,260
    Don't abandon caution though. Snow tires give you better grip, but they don't work miracles. Also, deep enough snow, you'll still be stuck, due to the low ground clearance.
  18. Mendel Leisk
    40,260
    It's strange to see New York with bare pavement, and here we've got somewhere around 8~10" of the white stuff right now. It's our first snow of the winter.
  19. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Good for you & all your new grip.
    You'll find that your rough limitation in this chassis is about ~12" of snow, more than that & you might get yourself into a
    sticky (pun intended) situation.
    Rob43
