Why won't the beeping stop!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Phoenix, Dec 16, 2018.
  1. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have a 2008 Prius with three hundred thousand miles on it and today while I was driving after I put my seatbelt on and the passenger seat belt then it still continues to beep like I am in Reverse even though I'm not in reverse and it continues to beep all the time now while I'm driving. WHen I slow to a stop that's the only time it stops beeping. I drive a lot even after 30 minutes this is starting to drive me insane and I don't know where to start seat sensor computer failure bad wire if anyone has any idea I love to hear about it
  2. JC91006
    JC91006 Senior Member
    16,935
    8,646
    Do you have something in the passenger seat? Did you say you put on the passenger seat belt?
    edthefox5 likes this.
  3. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    That's where I started to look there's nothing in the seat there was bags of food and I also have a null seat belt clip put in there but even when that was in or out it still beeps and the warning light that goes along with the seat belt beep is not illuminated either
  4. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    My working theory is the car still thinks it's in Reverse so I'm trying to turn off the reverse beep I have not had any luck yet
  5. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    So my working theory didn't work I was able to turn off the reverse beep but yet my car still beeps in drive while I'm moving
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Are all the doors secured and te sensors for seeing them closed working? Particularly the hatch?
    RachaelH and Mendel Leisk like this.
  7. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I don't even specifically know where the door sensors are but I will check everything usually when the there is a door ajar, there is a light on, on the dash and the dome light goes on
  8. Mendel Leisk
    42,289
    Yeah if you've got a blanket or similar protecting the hatch, maybe preventing the latch from fully engaging?
    I drove from North Coquitlam to North Vancouver with a caribiner pushed into the hatch latch, and the hatched tied down, transporting some shelving pieces that stuck out. Thought I was being clever, that the car would think the hatch was closed. Not!
    It beeped all the way to the second Narrows Bridge, which is when I realized I'd forgotten to bring along the all-important bag of screws. So all the way back to N. Coq., and then once again to the bridge and over to North Van. With the blessed beep for every meter of it....
    RachaelH and Raytheeagle like this.
  9. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    There usually easy to spot on each door. They’ll have a little tab that will compress.
    See if everything is working. The hatch can be a bit fiddly and usually will corrode out over time.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I worry that he seems to think it is an annoying beep rather than a warning beep.
  11. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I just checked all the doors and hatch nothing I could see or feel, and the reverse beep I just turned off is beeping again
  12. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    If it is true that it's warning rather than annoying so what is it warning me about? Does anyone have any ideas about what it may be rather than comments about my state of mind?
  13. JC91006
    16,935
    8,646
    Overheating, usually has a red triangle too
  14. Elektroingenieur
    2,515
    3,288
    Three Touring
    From the Owner’s Manual (PDF), starting on page 426, the most serious possibility is a failure of the brake system, or if the car detects that the parking brake isn’t released. In these cases, there would usually be a red BRAKE warning light, too, but this could have failed.
    In general, anything that causes a continuous beeping should also have an indicator or warning light or message. Many of these lights should come on briefly when you start the car, and then turn off, and it would be a good idea to check each one. In the Owner’s Manual, see the chart on page 149 and the illustration of the instrument cluster on page 146.
    jerrymildred and Mendel Leisk like this.
  15. ChapmanF
    18,969
    This may sound schoolmarmy, but is the OP reporting a continuous beep, or a continual one?
    Dire warnings from the brake system sound a continuous one. I think most other stuff like the seat belt or reverse warnings sound a continual one.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Is the passenger seat belt light on the passengers side dashboard blinking?
    That’s a beep beep beep.
    Contuniuous beep is uh oh.
  17. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Thank you all for your positive and constructive comments. The beeping was not from a seat belt or anything because there was no corresponding lights. It was like I was in reverse when I was in drive it was the exact same beep. So against my better judgment after a whole day and night of beeping I took it to a Toyota dealership. They could not replicate the beep, I even drove it with the tech, did not beep once unless the seat belt light was on. It hasn't made a sound since. They said they didn't do anything. At this point I was just glad it stopped. Now I'm on to another problem that is keeping my brake system lights on that is a very big concern. I replaced the rear wheel bearing, because of a speed sensor failure code. The lights have not turned off. I have tested the part it is not faulty. I have a new wire, which is what Toyota, an independent shop, and what my mechanic and I think should be the next step. Although I'm not too confident in the possible outcome. Thank you again everyone who offer ideas and advice
    Raytheeagle and bisco like this.
  18. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    After re reading the posts I wanted to say it was definitely a continual beep NOT a continuous one.
