Configuration for Amplifers
Discussion in 'Prius c Audio and Electronics' started by Hartish Khoobarry, Dec 16, 2018.
  1. Hartish Khoobarry
    Hartish Khoobarry Junior Member
    49
    Mauritius
    2014 Prius c
    Hi guys,
    Below I the configuration of my current audio system..
    How do I configure the gain and cut off frequency of each amplifier? The pioneer gm 9604 also has option to choos LPF/OFF/HPF.
  2. audiodave
    audiodave Active Member
    800
    272
    US
    Oh I want that processor!
    Well the cut frequency set for the driver your using. Sub probably 60hz, front and rear high pass at 60hz. Gain another story. That processor has a lot of output so I'm sure those need to be down.
  3. Hartish Khoobarry
    49
    Mauritius
    2014 Prius c
    Hehe..that a nice processor. What if I dont use filters for front and rear amplifier,?
  4. audiodave
    800
    272
    US
    Be sending low bass to the door speakers which can't produce it anyhow. Straining woofers and competing with the sub.
  5. audiodave
    800
    272
    US
  6. Hartish Khoobarry
    49
    Mauritius
    2014 Prius c
    Yep..I have installed this setup..not satisfy with the mid bass and loudness
  7. audiodave
    800
    272
    US
    Well not using the high pass filters to remove low bass from your main speakers won't help that. The processor will EQ the car out and should sound excellent.
