What oil should i use?
Discussion in 'Newbie Forum' started by DaveySocks, Dec 17, 2018.
  1. DaveySocks
    DaveySocks New Member
    Pittsburgh
    I have a 2005 Prius with 210k miles on it. I use it to Uber and Instacart and put about 500-700 miles on it a week. I'm going to change my own oil this weekend and would like suggestions on what would be the best. Also to note, the engine burns oil. About a quart every 1500 miles or so.
    51,025
    welcome! try some mobil one synthetic
  3. DaveySocks
    Pittsburgh
    Should I use 5w30?
  4. bisco
    51,025
    it should be on the oil fill cap. and in your owners manual
  5. DaveySocks
    Pittsburgh
    Thanks again!
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    When it gets to the point of using a quart in 1500 miles, I suggest that a heavier "high mileage" oil would be appropriate.
    Something like 15W40 maybe.
    OR if you are not concerned about adding a quart every 3 weeks or so, just keep using the oil that is recommended.
    "High mileage" oil might slow down the consumption; it might not too. But it certainly won't hurt anything.
    DaveySocks and Mendel Leisk like this.
  7. Mendel Leisk
    40,470
    Yeah "high mileage" oil is kind of a one-way thing, swells rubber seals compared to regular oil, and once you start with it you best stick with it. Reverting to regular oil the oil consumption could increase with a vengeance. But when you're into such high consumption, it's probably for the best: the engine is getting near "terminal" anyway.
    DaveySocks likes this.
  8. DaveySocks
    Pittsburgh
    I ended up using 0w20 full synthetic high mileage. So far so good.
  9. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Extra-virgin olive would be a poor choice. Barring that, for a car that uses oil, you want something good but cheap. I'd try Wal*Mart SuperTech High Mileage.
    Skibob likes this.
  10. JC91006
    JC91006 Senior Member
    16,656
    8,504
    Why such a thin oil? You'll only burn it faster
  11. sam spade 2
    7,035
    2,798
    2017 Prius c
    I assume that is what "the book" recommends.
    And some people seem to persist in thinking that their car will explode if they use a different weight oil.
    Skibob likes this.
  12. Mendel Leisk
    40,470
    The 2nd gen Owner's Manual spec's 5W30. Not sure how critical that is though: it seems with every gen they spec a thinner oil.
  13. sam spade 2
    7,035
    2,798
    2017 Prius c
    Well then his plan is NOT good.
    Absolutely NO reason to start using a thinner oil in an old engine that is showing signs of wearing out.
  14. Mendel Leisk
    40,470
    It'll be a battle, between the thinner oil and high mileage component. :sneaky:
