is my 12v battery really dying?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Quickie, Dec 20, 2018.
Tags:
  1. Quickie
    Quickie New Member
    Seattle
    Three Touring
    My car says my battery is fine. It meets the minimum voltage requirements in all modes. It is exactly 12v for instance when the battery is on. And 14v in ready mode. Maybe it's dipping occassionally? The problem is my car doesn't start and the clock resets. Is it possible that the battery is going bad but most of the time works well enough to pass diagnostic tests? Thanks in advance.
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Welcome to PriusChat!!
    12v is generally considered low for an AGM battery.
    Grab a multimeter and check the jump points under the hood, don't rely on the diagnostic tests.
    When was the last time it was changed, and how often to do you drive (example: 1 hr per week) ?
    Cool screen name :whistle:
    Raytheeagle likes this.
  3. Mendel Leisk
    41,329
    Not sure what you mean by "on". How are you measuring voltage, via the car's displays? If so, that will maybe depress voltage slightly.
    A more accurate voltage reading would be with a separate multimeter, preferably digital, while the car is off. If you get 12.0 volts by that method, yeah: that's a near-dead battery:
    (the above chart is for conventional flooded acid 12 volt; the AGM style used in Prius should read 0.1~0.2 higher)
    Pick up something like a Solar BA5 and you can see for yourself how it is.
    First question last: how old is it?
  4. padroo
    padroo Senior Member
    2,763
    2,252
    12 Volt battery problems are probably the number one question on Prius Chat.
    jerrymildred likes this.
  5. bisco
    51,843
    and the number one answer :D
    SFO and Raytheeagle like this.
  6. bisco
    51,843
    welcome!
    very possible.
    check the connections for tightness and cleanliness, especially negative to ground.
  7. Quickie
    Quickie New Member
    Seattle
    Three Touring
    Thanks. I took it in to the Toyota dealership and they told me the battery was bad. I changed it but many of the screws were stripped so I had to take the thing next to the battery out in an unconventional way. What is that thing called? Usually they suggest taking the 12mm screws out to remove it, but since they were stripped I took out the side screws. At any rate I couldn't get the back screws in because of the angle. I took it back to Toyota and the mechanic said everything's secure. But I still feel uncomfortable not having those screws in. Especially since I don't even know What's not screwed in.
    SFO likes this.
  8. Quickie
    Quickie New Member
    Seattle
    Three Touring
    Thanks for the chart... And it was low. Got a new Battery.
