has Toyota fixed the "mouse problem" with the Gen 4?
Discussion in 'Gen 4 Prius Main Forum' started by sirhcwarrior, Dec 20, 2018.
  1. sirhcwarrior
    sirhcwarrior New Member
    Brewerton, NY
    I have a wooded lot in suburbia and i KNOW there are mice present. I JUST brought my new (to me) 2016 Prius home yesterday, and joined Priuschat mainly to ask about what people have liked/used as an all-weather cover. I stumbled onto the "mouse problem" threads and now i'm wondering if i should cover my Prius at all (and give the little buggers an ever greater reason to try to get inside my car).
    Anyone with a Gen 4 have this problem, or did the redesign address it?
    ~chris
  2. Mendel Leisk
    41,255
    Have a look at yours. Is the engine air filter snorkel sitll open at the end (no mesh or whatever)? Is the cabin air intake still similarly open? How about the hybrid battery exhaust air ports?
    That's just for cabin incursions. It's pretty much impossible to protect under-the-hood, or any exposed wiring.
  3. bisco
    51,812
    i don't recall any vermin reports yet. might have missed them though. i don't recall anyone including toyota reporting better sealing of mouse entry points. might have missed that as well.
    alanclarkeau and sirhcwarrior like this.
  4. Mendel Leisk
    41,255
    I would suggest to be proactive, not wait till you see the droppings, shells and nesting material. ;)
  5. sirhcwarrior
    Brewerton, NY
    oh, i already put peppermint essential oil drops under my hood and soaked Q-tips under the storage compartment and a few inside the cab. likely i'lll add balsam fir as well. what i wanted to know is if the extensive interior re-design they apparently did on the Gen 4 actually fixed some of (or all of, but i'm not that optimistic) entry points. i haven't looked yet, since i JUST got the car, but i figured i'd ask here in the Gen 4 forum.
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    Or get a cat.
    alanclarkeau likes this.
  7. Mendel Leisk
    41,255
    Shiba Inu did the trick for us, for a small rat that was dividing it's time between under the hood and various spots around the garage.
  8. sirhcwarrior
    Brewerton, NY
    i have a cat, but i'm unlikely to store her in my car.
    i DID brush her and also stick some of her fur in a couple spots.
    alanclarkeau, krmcg and bisco like this.
  9. krmcg
    2,592
    2,392
    Whittier, CA
    Not by the fan I hope
  10. Tande
    Tande Active Member
    537
    321
    Mich.
    Quite sure I saw a post here on PC somewhere, about a nest on top of the cabin filter.......yes, Gen. 4......:(
    sirhcwarrior likes this.
  11. sirhcwarrior
    Brewerton, NY
    where is that? (asks the person who has had Honda Civics for 15 years previously)
    edited: ah, ok, Google has it behind the glove box? so under the hood/in the hood compartment. *sigh*
    #11 sirhcwarrior, Dec 20, 2018
  12. Tande
    Tande Active Member
    537
    321
    Mich.
    Well......yes, behind the glove-box, but ALSO inside the cabin......;)
    krmcg and sirhcwarrior like this.
  13. sirhcwarrior
    Brewerton, NY
    huh, ok, so that incursion could be fixed with the mouse-proofing of the cabin that has been posting in other threads? i'm just trying to figure out if my 2016 likely needs it/has those incursion points still, and if i should plan to do this fix. looks like maybe i should. is there a way i can search for the post you saw? i tried searching the Gen 4 forums for "mouse" but didn't get a hit.
  14. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    maybe try searching for "rodent"? I do recall one which had under-bonnet damage but can't recall the outcome.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My car doesn't have a mouse, it's all touchscreen and buttons. :whistle:
    krmcg, jerrymildred and bisco like this.
  16. bisco
    51,812
    short changed?
    kithmo likes this.
  17. sirhcwarrior
    Brewerton, NY
    that did it, thanks. it actually brought up two. :/
    ~chris
