2019 has visor extenders!
Discussion in 'Gen 4 Prius Main Forum' started by Mithrandrost, Dec 21, 2018.
  1. Prodigyplace
    12,526
    11,747
    Central Virginia
    You realize the topic here is the 2019 Prius Liftback not the Prime right?
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    Is the prime not a hatch also?
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    There's been no mention of flow-on to the PRIUS PRIME ... yet - this is a Gen 4 thread.
  4. Prodigyplace
    12,526
    11,747
    Central Virginia
    They are viewed as totally different models by Toyota. The 2019 Prime may or may not have visor extensions. Likely they do not. Toyota has coined the term Liftback to distinguish between the regular Prius and the Prime.
    Some parts are interchangeable across these models but not all.
    alanclarkeau likes this.
  5. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    On my end I am curious to know if a retrofit will actually work. Secondly, length of time to order and cost.
    Thinking that I may just be cheap and get the driver's side visor...
    krmcg likes this.
  6. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    I ordered the aftermarket visor-extenders 2 days ago, for both of our Prime. The vendor sent an email to confirm proper fit. Correct for Prime was confirmed and they are now being shipped. I'll have them in a few days...
  7. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    That's because carbon fiber is extremely light. Weight has a direct correlation to fuel savings, which is what the Prius' primary job is.
  8. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Sunglasses
  9. omarg
    omarg Junior Member
    Athens Georgia
    any update on this? care to share where you got em? Thanks!
  10. john1701a
    12,817
    5,303
    58
    I totally forgot... since that was winter, several months before any drive actually needing them. We used them recently. Worked great. Takes 30 seconds to setup.
    Gray Set of Visormates- Side Window Sun Visor Extenders
  11. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Bumping my own post... Wondering if anyone has pursued this yet? Part number? How to? Please share.
  12. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    In case people were wondering what they look like.
    davran, ice9, antiglare and 3 others like this.
  13. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Giving my post another bump... Wondering if anyone has made the switch? If so, what was the result?
  14. Prodigyplace
    12,526
    11,747
    Central Virginia
    We were waiting for you to be the first. ;)
    krmcg likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Too late! :) See posts #6 & #12.
    Sliding sunvisor on the 2019 | PriusChat
    I couldn't find it, but somewhere there's a post where someone said they installed the new visor and it was a perfect fit. They loved it in spite of the big gaps it still leaves.
    Here's someone else.
    2017 Prius Prime sun visor | PriusChat
    edit to add:
    also, see @Hidyho's post #32 in this thread for a picture of how they look in his 2018 Prius.
    Prodigyplace likes this.
  16. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    I'm astonished that '19 is the first year with visor extenders in the prius; I'd not have bought a car without them. Heck (yes heck), my '00 grand cherokee had them.
  17. bisco
    51,837
    it was just one of toyota's sticking points, for whatever reason
  18. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    UK-spec 2019 models still don’t have them. Presumably Toyota thinks, not unreasonably, that we never get any sun.
