2014 Camry won't turn on, check hybrid system
Discussion in 'Toyota Hybrids and EVs' started by Priusprofit, Dec 28, 2018.
  1. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Hello PC,
    I'm having a very miserable night with my first hybrid camry repair (I'm a gen2 prius guy)
    Hopefully somebody can give me some insight as to what is causing this no start issue.
    Initial issue was the Check Hybrid System warning on the car, but the car still drove, the obd port was not functional so I was not able to scan it but the owner of the car says there was a p0a80 code when it did work.
    I removed hybrid battery and to my surprise modules tested between 7.94 and 8.21
    I assumed it was the variance in voltage that was the problem, I removed modules from existing battery and put them in another battery I had which made voltage between 8.03-8.16
    I installed that battery and the car would not turn on, sometimes ready would flash 2-3 times sometimes it wouldn't turn on at all.
    I checked all plugs and ground connections and couldn't find anything wrong.
    I swapped the junction box and the battery voltage sensor from the original battery thinking that could be the problem and the problem persists.
    Any suggestions as to what the problem/solution could be would be greatly appreciated.
    In the meantime I am putting modules back in the original battery but realistically what is there that wasnt put on the other battery? The temp sensor and voltage sensor harness?
  2. JC91006
    JC91006 Senior Member
    16,656
    8,504
    Your orange interlock on the battery should be locked, flip up and slide down (in gen2, it's down) to lock it
    Raytheeagle likes this.
  3. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Yes, that is inserted correctly.
  4. JC91006
    16,656
    8,504
    Did you check your 12v voltage?
  5. egn83b
    egn83b Junior Member
    59
    Rarford nc
    Most hybrid systems will not work tell you balance charge the battery pack. Meaning you need to put all the cells in parallel and charge em tell they are all 8 volts equal. Then and only then will the hybrid system accept and run the car correcly small variances are tolerable but anything a 20th of a volt is usually red flagged by the bms and the car will limp or may just sit idle.
  6. JC91006
    16,656
    8,504
    Where did you get this info from?
  7. egn83b
    59
    Rarford nc
    I learned from diy experiance and alot of forums online. Mostly on my honda ima cars and studying the mode of failure on the toyota hybrids when the bms flags the ecu of a battery issue. You need a scan tool to monitor the cells from the bms in the toyota. A torque app from the android play store and bluetooth adaptor obd adapter.
  8. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Upon arrival the modules ranged from 7.94-8.21 and the car was running and driving, they now range from 8.03-8.16 and the car does not ready on.
  9. Priusprofit
    Priusprofit Member
    96
    32
    Long island
  10. egn83b
    59
    Rarford nc
    The other thing you need to check is your battery contactor if its clicking when you press the on button.
  11. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    It does click, that is in or near the junction box?
  12. JC91006
    16,656
    8,504
    Have you grounded the battery case to the car? Put in the mounting bolts
  13. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Yes
  14. JC91006
    16,656
    8,504
    What's the voltage on the entire battery pack? I still think you don't have the orange interlock locked in place.
  15. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Where do I get that voltage reading from? 2014 camry battery
  16. JC91006
    16,656
    8,504
  17. Priusprofit
    Priusprofit Member
    96
    32
    Long island
  18. JC91006
    16,656
    8,504
    You would have to trace your steps, check if all the bolts tighten, all the connections tight. No reason it won't start now, it's in the battery connections
    Try disconnecting the 12v negative and reset the car
  19. egn83b
    59
    Rarford nc
    Make sure to check all fuses and also do a reset of the small battery before and after all wiring changes so the ecu can reset and relearn. Best of luck on your car.
  20. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Removed and reinstalled battery twice checking everything, I was just able to catch the obd port working long enough to get codes and I have:
    P0b79 (hybrid battery voltage sense M circuit low)
    U029A (lost communication with hybrid battery pack sensor module)
    P0A80 (replace hybrid battery pack
