17" OEM Toyota Wheels - Anyone?
Discussion in 'Prime Accessories and Modifications' started by 303inthe510, Apr 17, 2018.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Certainly anything in life can break, especially if you hit it/damage it with enough force....
    Rob43
  2. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    douglasjre likes this.
  3. Woodman411
    Woodman411 New Member
    New York, NY
    Really, which ones? The ones I see for the Toyota Corolla, for example, most of them are made in Japan or US, but there are a few with no origin (origin is in the Description): OEM Corolla Wheels - Olathe Toyota Parts Center
  4. Mendel Leisk
    40,974
    Is there any indication on the rim? I've got a set of OEM 17" rims loose in the garage right now; is there a country of manufacture embossed? They're under a cover; I'm kinda lazy but could look if worthwhile.
  5. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    I received this from the dealer in response to my request for a spare.
    It matches the 3 rims I bought on E Bay as described: 15" INCH TOYOTA PRIUS 2010-2015 OEM Factory Original Alloy Wheel Rim 69567A
    I'm using the 4 rims for my snow tires.
  6. toyopri808
    toyopri808 Active Member
    226
    116
    my OEM 15's were stamped Japan
  7. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    The first time uploading on this forum so a bunch of pics.
    I don't know regarding the Japan wheels - the pics are of the new rim received from the
    dealer in June 2018, but it matches (incl. "China") on the wheels I purchased on E-Bay and those
    were represented as "Prius 2010 - 2015"
    I'm riding around on them now.
  8. Mendel Leisk
    40,974
    And really, what's the difference? :confused:
  9. Woodman411
    New York, NY
    Between genuine OEM China versus genuine OEM Japan and USA? Don't know. My point is not this tangent, rather, cheap light wheels (where most are made in China) can't be as strong as heavier OEMs at similar price points. In regards to wheels and really any metals, it's a balance of strength, weight, and cost (pick two). In areas where potholes or rough roads are an issue, and I'm in NY, this is why I asked about wheel strength measurements.
    #29 Woodman411, Jan 18, 2019
