Just got my 2010 and have P0A80 and C1241
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dmc88, Jan 17, 2019.
  1. dmc88
    dmc88 New Member
    Draper, Utah
    Hey folks
    Im new around here but I just got my second Prius. My first was an 07, then I got a lexus HS that i still have and just today bought a 2010 Prius 5 with Advanced tech package for $5700.
    When I got home from the transaction i was playing with the computer and noticed the trip computers we both reset. That made me a bit curious so i dug out my obd2 scanner and saw that i have codes P0A80 and C1241. I did some digging around the interwebs and didnt find anything that would make those 2 related. Can they be?
    Is it a charging issue with the alternator or 12v battery or am I just in denial about buying a prius that needs a new hybrid battery?
    Thanks in advance!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • How many miles on your Prius?
    • What did you use to read te codes?
    • Did you pull any sub codes from the P0A80?
    • How did the car run once the dash lights appeared?
  3. JC91006
    JC91006 Senior Member
    16,747
    8,552
    $5700 for a 2010 V with tech package, wow that's cheap.
    So I would just put in a new battery for $2000 and call it a day. Out the door for $7700. You will then have trouble free driving for 8+ years (fingers crossed).
    Raytheeagle likes this.
  4. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    Depends on the mileage or condition;).
    $5700 sounds too good to be true territory :cool:.
  5. dmc88
    dmc88 New Member
    Draper, Utah
    So the interesting thing is that nothing is showing on the dash. It runs and drives fine. I have a Lemur BlueDriver scanner. I cleared the codes and re scanned and it only threw the P0A80 code. .
    183k
    Drove around all afternoon and nothing came up. Battery seemed to charge fine and didnt drain when I floored it.
  6. dmc88
    dmc88 New Member
    Draper, Utah
    Update:
    Went to the dealer to get an oil change and asked. The advisor said that if there are no warnings on the dash its all good. Can I trust that?
