New prius - Fobs don't work well?
Discussion in 'Gen 2 Prius Main Forum' started by thockin, Jul 20, 2004.
  1. thockin
    thockin Junior Member
    57
    San Francisco, CA
    I just got my Prius, and I am very frustrated.
    Most of the time, when I approach the car, the Smaert Entry does not work. Sometimes it works if I stand there for 3 or 4 or 5 seconds.
    When I try to manually lock teh car, nothing happens, most of teh time. Ditto for unlock.
    I'm trying to program the SE mode, and I'm holding Panic and Lock, but nothing is happening.
    Anyone have ideas?
  2. DaveG
    DaveG Member
    806
    Vancouver, BC
    Hmm... Don't know. That's not the normal operation of the system. The SE should activate the instant you touch the door handle on either of the front doors.
    Maybe it's a faulty fob or a low battery? Have you tried the second fob?
    Dave
  3. thockin
    57
    San Francisco, CA
    Both fobs act (or don't, more properly) the same.
    Holding teh panic button causes nothing to happen.
  4. jamarimutt
    jamarimutt New Member
    985
    The smart entry system activates when you touch the black strip located on the inside of the door handle; walking up to or standing near the car won't do it. I programmed the SE mode while sitting inside the car; try that to see if it helps. Also, make sure the SE on/off switch (below the steering wheel) is on.
  5. daniel
    14,487
    1,519
    Spokane, WA
    If the panic button does nothing, something is wrong. Take it to the dealer.
    Very rarely, when I grab the door handle, nothing happens. I have to take my hand away and try again. But this is rare. From your description, there is a defect somewhere.
  6. aarons12
    aarons12 New Member
    704
    long island, NY
    my car unlocks just as i'm reaching for the door handle. the only time i actually have to touch it is if i am opening the rear hatch first. i love it. sounds to me like there is something wrong with the system.
    on the other hand, i have been waiting over 3 weeks for my dealer to get back to me regarding the problem with my nav screen. supposedly their toyota regional rep was on vacation. so good luck getting them to respond to a problem with something that's unique to the prius (sigh)
  7. jchu
    jchu New Member
    1,063
    Nampa, ID
    When you press any of the buttons on your fob, does a red led just to the right of the lock button come on? If it doesn't the problem is likely a dead battery.
  8. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    The inside of the door handle doesn't require pressure to unlock, but dry hands may not conduct enough electricity to make the door work. I've barely touched the handle in the past and it unlocked, but sometimes a firm grab was ignored.
    That no-panic panic button needs looking into...
  9. daniel
    14,487
    1,519
    Spokane, WA
    When I took delivery of mine in January, they warned me that it might not work with gloves on. But in fact, it always did work with gloves on. No more gloves now, not for a couple of months, anyway.
  10. eg239
    eg239 New Member
    73
    Manchester, NH
    Is the extra fob still in the car?
  11. jamarimutt
    985
    I believe that you have to press and hold the panic button for at least a second before it will work.
  12. woemcats
    woemcats New Member
    75
    Northern Illinois
    Also if SE doesn't work, make sure the fob is close enough to the cer. If I reach for the handle with the fob in my pocket, sometimes it is too far away and I have to step closer.
    If SS is working without the key in the slot, then I don't know why the other functions wouldn't.
  13. thockin
    57
    San Francisco, CA
    It seems to work now. I'm out of town this week, but I'll check it again when I get home...
  14. bigal
    bigal Junior Member
    28
    Hamburg NY
    Signal could be blocked
    What else do you have next to the FOB. I have found that the FOB will not reliably function if I have it in my pocket next to my PDA. I think the PDA may be shielding the FOB such the signal doesn't get out. Other things could be doing the same.
  15. AlphaTeam
    AlphaTeam Member
    643
    Earth
    How much are extra Fobs?
    Alpha
  16. maxvok
    maxvok New Member
    Netherlands
    Standard FOB fails
    After taking some photos while on holiday in South France, I was unable to start the car after inserting my FOB (I have the standard Prius, i.e. no smart key) despite various attempts including turning it, dashboard did not light up. Had already arranged to be towed away when I remembered that I had a reserve FOB and after trying that one, I was able to start the car again normally. About an hour later I tried again to use my original FOB and it worked again ! After studying the manual, I remain puzzled what the cause could have been. It was not unduly hot (about 80F) and I had kept the FOB in my dry shorts pocket while taking the pictures, not sure if my mobile phone was in the same pocket, probably not. This happened after having the car for 4 months and driving about 3000 miles so the battery in the FOB should be still ok, dealer recommends to replace it once a year.
    Lesson learned: keep always the spare FOB with you.
    Question: Did anybody have a similar experience ?
  17. mshappe
    mshappe New Member
    88
    Richfield, MN
    Re: Standard FOB fails
    The more I hear of situations like this, the more I think that Toyota's rolling-code scheme for the starter system is a bit fragile and needed a bit more debugging before being set loose in the wild.
    Won't stop me from buying a Prius as soon as one comes available :) I just hope Toyota are looking into issues like this...
  18. Ray Moore
    Ray Moore Active Member
    857
    52
    If my fob is in my pocket with my cell phone I often get a delay or malfunction when trying to lock or unlock the door. When they are in opposite pockets, I don't have a problem.
  19. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    That's most likely because your cell phone is constantly sending out radio frequencies looking for network notifications like signal strength, voicemail, text messages, etc.
    Ever noticed how you can get a voicemail notification sometimes when you never received a call because of poor coverage? That's why.
    I bet it's those waves that are intermittently interfering with the FOB.
  20. mshappe
    mshappe New Member
    88
    Richfield, MN
    Radio interference is a funny old game, really.
    Anecdote #1: There's a coffee shop near my house with fantastic, free WiFi availability, but lousy cell phone reception. My first theory was that the WiFi was interfering (probably part of it, actually); my second was just that the building was an accidental Faraday cage, not designed with the idea that one day people would be sitting in it wanting to receive phone calls. But it was also pointed out to me that the upper storeys of the building include several medical clinics, with X-Ray and other imaging systems...
    Anecdote #2: Whenever I park in one particular spot on the street near one particular friend's house, my car door remote (non-Prius) fails to work well. One time I actually had to get *into* the car (using the old-fashioned key) and set off the alarm before I could finally get the remote to be recognised! There is absolutely nothing obvious at that street corner -- not even an electrical transformer -- to explain this phenomenon, but I've had it happen to me three times now. (And yeah, I know, I shouldn't park there :) Sometimes it's the best spot!).
