2007 engine swap no start no ready light
Discussion in 'Gen 2 Prius Technical Discussion' started by Sharnold, Jan 16, 2019.
  1. dolj
    dolj Senior Member
    8,186
    4,168
    Wellington, New Zealand
    215 V is the minimum, so better than that.
    What it shows is 40% to 80%, which is the range used by the control computer.
  2. JC91006
    JC91006 Senior Member
    16,656
    8,504
    He's only got 1 choice, not 2 choices. Needs a new battery
  3. Sharnold
    Sharnold Active Member
    394
    123
    Alabama
    I concur sir
  4. Sharnold
    394
    123
    Alabama
    New dilemma the owner of the car bought this one from a auction wrecked in the front drivers fender he had painted and fixed the car before bringing it to me. Now the issues the reason the head gasket was blown was due too the previous owner or him driving the car with the coolant heat storage tank busted. Now my question as I looked up in the fender last night I noticed plugs AM1 and AM2 are bundled together with electrical tape I did have to replace the inverter and AM2 fuse was never blown but could this be my no start no ready culprit?
  5. Sharnold
    394
    123
    Alabama
    Is there anyway possible to charge said hv battery in neutral and spinning the axels........hypothetical question as I know the cvt will probably not engage to charge without proper voltage. I ordered a battery this is off subject banter
  6. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Nope and not advised to put the car in neutral for most reasons;).
    edthefox5 likes this.
  7. Sharnold
    394
    123
    Alabama
    I've read its quite possible but at a risk of overheating or overcharging the battery or ruining the cvt. The next wrecked prius I take in for parts I might brace it out and test
  8. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Where did you read it is possible :whistle:?
    I’m from Missouri on this one;).
  9. Sharnold
    394
    123
    Alabama
    Well guys I lucked out the car cranked o gave it one more go before pulling the hv and low and behold she runs and battery is no longer depleted and charged
