Is 12 Volt Gen 4 Battery Made of Gold?
Discussion in 'Gen 4 Prius Main Forum' started by ATHiker, Jan 23, 2019.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Interesting - they must have changed it after 2016 sometime.
    I assume yours is the original battery - it's unusual that it says something about "Distributed by TOYOTA USA" - as though it may not be the original. Or are PRIUS being made in USA nowdays?
    Prodigyplace likes this.
  2. Prodigyplace
    12,398
    11,676
    Central Virginia
    Quit spreading your FUD. It is a flooded lead acid battery.
    From https://www.napaonline.com/en/p/NBP75140R
  3. Prodigyplace
    12,398
    11,676
    Central Virginia
    That is not the factory battery. The car & OEM battery were made in Japan.
    alanclarkeau likes this.
  4. bisco
    51,055
    referring to post #
    no worries, not to your posts
  5. bisco
    51,055
    fear, uncertainty and doubt? no, just saying it is not a normal battery. in regards to size and fitment, you have not shown otherwise.
    the question was: will a dealer honor their $99. 12v battery special, and my answer was no, that is only for normal batteries.
    a toyota dealer will honor it for a camry (normal) but not for a prius (abnormal) i.e. rare and expensive
    Raytheeagle and alanclarkeau like this.
  6. alanclarkeau
    7,045
    7,589
    If that's the case - my assumption is that they may have replaced it before they sold it to you - possibly it was left flat?
    In which case - stop worrying for another 7 years as it's under a huge warranty.
  7. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    I just started another thread on this, because of the voltage readings I'm seeing on this battery, whatever its source. Worry isn't quite the right word, though I'm not in a situation where car malfunction-induced lateness is acceptable -- so I'm getting ahead of it early -- before it becomes critical. And again, the car is two weeks old (to me) so I've got Toyota dead to rights on the wty.
  8. bisco
    51,055
    they won't warranty unless it tests bad. best to keep an eye on it.
  9. alanclarkeau
    7,045
    7,589
    I've asked the Moderators to move the new thread back here - otherwise we've now got 3 threads running in parallel about the same issue.
    Stop worrying - you've got years and years left on your warranty.
  10. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Either way works for me, the issues are distinct, but pretty close...
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    BUT.....there is NO reason that a replacement can't be an AGM type, when the time comes.
    Maintenance free and likely longer life.
  12. Salamander_King
    Salamander_King Senior Member
    11,004
    8,926
    New England
    Sure, if my dealer installs it for $99 battery special. ;)
  13. bisco
    51,055
    why not? it's a normal battery :cool:
  14. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    NAPA The Legend Professional Battery BCI No. NA 445 A Wet
    Part # : BAT 75140R
    Product Line :
    NAPA Batteries
    A friend called, frantic, after our wonderful Guam Dealership quoted her $900 installed. I found this identical battery at NAPA. Even on Guam it was $203.
    Grabbed a toolbox and ran over, was stunned to find out you don't even have to take apart the back end of a Gen 4 (we have a Gen Two, a Gen 3, and a V). Its right under the hood, like a normal car, so took ten minutes.
    I needed a 12 km socket, extension and ratchet, a 10 mm socket, a 10 mm wrench and a little common decency saved her $700. Unconscionable.
    Salamander_King likes this.
  15. Prodigyplace
    12,398
    11,676
    Central Virginia
    How did you move that 12 km socket and how did it help???
    I hate to think how much THAT cost
    alanclarkeau and Tande like this.
  16. Mendel Leisk
    40,508
    I was gonna say @Prodigyplace will be along shortly; he beat me to it.
    alanclarkeau and Prodigyplace like this.
  17. alanclarkeau
    7,045
    7,589
    Yep - I sent it to a mate - he suggested that they used something like a squadron of these to handle it.
    MEANWHILE - this was in the news today ... nothing to do with 12km sockets, nor batteries, nor PRIUS - only thing relevant is that it's got 4 wheels - well, here it is.
    Prodigyplace and Mendel Leisk like this.
  18. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Well, duh! She was on the other end of the island!
  19. Prodigyplace
    12,398
    11,676
    Central Virginia
    For the metric challenged Americans we have been joking about a 7 mile wrench. 12km vs 12 mm
  20. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    The best part -- for decades I have made understanding and using the metric system a primary focus of my freshman level science classes. Makes the km vs mm typo that much better.
