Back Seat not folding down flat
Discussion in 'Gen 4 Prius Technical Discussion' started by Reference36, Jan 27, 2019.
  1. Reference36
    Reference36 New Member
    San Diego CA
    Two Eco
    Hello all,
    I'm new here. I have 2016 prius and my back seats don't fold down flat. There is like a 4 inch incline to make things worse there is a hard plastic cover that's on the bottom of the seat that folds up and sticks up too! No too good for lying down back there.
    I must be doing something wrong. Can anyone let me know if the back seats are supposed to close and lay so that you have a flat surface?
    Thanks!!
    51,054
    welcome!
    i think that's the way it is, and you have to build up the hatch floor to make it level. see the camping threads.
    all the best!(y)
  3. Mendel Leisk
    40,508
    Maybe it's flatter on levels with the spare?
    Prodigyplace and kithmo like this.
  4. Reference36
    San Diego CA
    Two Eco
    Oh man that's too bad makes things less convenient. I don't have the spare. Thanks everyone! Look forward to learning more about the car.
  5. krmcg
    2,592
    2,391
    Whittier, CA
    I built my cargo area up with styrofoam (with holes for storage) to allow for a flat rear seat folded area.
    bisco and alanclarkeau like this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    @JimmyPri did some considerable camping modifications. I think there were a few others.
    Here's one of his threads - and a YouTube to go with it.
    Essentially - TOYOTA, and just about every other manufacturer focuses on many, many factors in designing a car. I think the last thing they think about is camping modifications. Though - PRIUS is good in that the Climate Control can be left running for a comfortable time camping - but I'm sure TOYOTA didn't think that through.
    It depends on whether you've got a spare of not - but neither are level. With the donut spare, it starts at the same level as the boot floor, but the folded backrest is at a slight angle. You'd want your head up that end
    I believe that if you don't have a spare, there is a drop - which you'd need to pack up as well as the slight slope.
    [what is the instrument?]
  7. FuelMiser
    FuelMiser Senior Member
    1,339
    918
    Monument, CO
    No, it's normal in models without the compact spare. In models with a spare (3 Touring, at least) the floor is raised up to the level of the back seats when folded.
    Prodigyplace and bisco like this.
  8. Mendel Leisk
    40,508
    I think though, with a hatchback, it should be paramount, to have threshold flush with the interior floor, and the hatch floor level and unvarying, all the way forward to the end of the (folded down) rear seat backs. Essentially making the vehicle a mini cargo van. The Matrix was a good example, got that right. I believe hatch floor and rear seat backs were both a durable vinyl material of some sort, very easy for sliding things.
    Our third gen is pretty good, I think once you get into the backseat zone there's a slight slope, but everything's pretty seamless, no ups/downs, fairly easy to slide things in, uniform support, say for items like a flatscreen tv.
    alanclarkeau likes this.
  9. alanclarkeau
    7,045
    7,589
    Good in theory - but in practise, most cars don't do it very well. I've had 6 hatches - and only about ½ have had perfectly level. One of them was dead level, but there was a step from the boot area. It will only be level generally if the cushion folds forward and then the backrest folds down. Which can't happen with a PRIUS - there's a battery there!!!
    When the backrest fold down over the cushion, as many hatches do, it generally doesn't get a good flat floor.
  10. bisco
    51,054
    the problem with toyota, and most (all) manufacturers is, they don't make a habit of retaining the good when redesigning.
    the new design takes precedence over function in many cases.
    good function often gets compromised for questionable design improvements
    Prodigyplace likes this.
  11. alanclarkeau
    7,045
    7,589
    About the only one I can recall with a good flat floor in 2016 was the HONDA JAZZ/FIT
    Others - not so much
    Honda Civic:
    Mazda
    AUDI
    SUZUKI
    FORD FOCUS
    GOLF
    The Electric Me and bisco like this.
  12. Mendel Leisk
    40,508
    Ours has a slight uphill slope, but all-in-all, pretty level.
  13. fuzzy1
    10,335
    I thought the Gen2 Prius was quite good too, at least according to old posts. The Gen3 didn't do nearly as well on this.
    #13 fuzzy1, Jan 28, 2019
  14. alanclarkeau
    7,045
    7,589
    That's much the same as Gen 4 - which the OP was concerned about. It's flat enough to take a Flat Screen TV - I took some IKEA "wonder why there's an extra screw" boxes for a friend last week, and it was fine, despite it having glass panels.
    I've considered camping - I'd put my head at the steering wheel end if I did.
    This is mine:
    But will depend on 1) does it have a Full Size Spare (no); 2) does it have a Donut Spare (yes); or 3) does it have NO Spare (no).
    kithmo and Mendel Leisk like this.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Mine's flat like that now, originally I had no spare and the gunge kit, but the dealer agreed to give me a space saver spare wheel and the surrounding foam as part of the purchase deal.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Yeah, I don't want to brag...
    But the Honda Fit, excels at it's flat load floor, and configuration ability of the seats. For a sub-compact vehicle it's actually pretty amazing what you can fit in a "Fit".
    There's some design elements in a Fit that I don't know why other manufacturers haven't copied. The "Magic" seats, the flat load floor, rear seat head rests that can be made level with the seats themselves. Just little things everyone could do.
    Once designed into the vehicle, I can't believe making seats that can be flipped up, or headrests that can be pushed down, really cost that much more to produce.
    But the standard seems to be, just being able to flip the seats down. If you end up a little uneven? They are thinking you won't really notice or care in the ether filled oxygen of a dealership showroom.
  17. Prodigyplace
    12,398
    11,676
    Central Virginia
    I think there is only one country (Israel?) that gets the full size spare.
    The others are either donut spare or no spare.. More & more we are seeing no spare.
    The Prime cannot even use that wasted space! The new e4WD has no spare.
  18. alanclarkeau
    7,045
    7,589
    The Fit (Jazz) was the first photo in my gallery in post #11. Yes, they're amazing. I remember the first hatchback I saw, the Renault 16, the amazing multi-folding seats - in 1965. It took till 2001 for Honda to do something almost as good - and most others haven't caught up with it - apart from the Honda HRV I think it's called. But - as I say, probably everyone is "happy enough".
    Prodigyplace and The Electric Me like this.
  19. alanclarkeau
    7,045
    7,589
    I think someone commented on other countries in the Middle East - definitely Israel.
  20. The Electric Me
    9,083
    5,800
    That 1965 Renault...is very "Magic Seats" like.
    Guess the moral of the story is nothing is really "New".
    Sorry, this is PRIUS chat..not Honda Fit chat....but if I could indulge myself one more time, I'd say Honda has what they call the "Refresh" mode with the Fit...which is like the Renault, pictured above, the ability to fold the front seat back down, flush and even with the seat bottom of the rear seats, effectively creating a long "Lounge" like seat. You can sit in the back seat...with your legs stretched out to the end of the front seat.
    I love that feature for long drives, at rest stops. Allows me to drive a Sub-Compact, but create a seat with stretch out leg room, that is unrivaled by the most expensive luxury vehicle. Of course it's ONLY for rest...when completely stopped. But it's great on a long trip. I can take REAL naps on a long trip.
    Maybe I'm underestimating how difficult it really is to employ design change? But really some of these aspects you'd think would be pretty easy to do.
    IMO Honda doesn't "sell" what they have done right with The Fit aggressively enough.
    It's not a Hybrid, but as a utilitarian, all purpose, hatch-back, it's a great product.
