Headlights too high?
Discussion in 'Gen 4 Prius Main Forum' started by BoltonJoe, Feb 7, 2017.
  1. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    I remember in the 70s when Halogen bulbs came out, how bright they were compared to the regular (orangey) filament bulbs of the era.
    alanclarkeau and fuzzy1 like this.
  2. Prodigyplace
    12,398
    11,676
    Central Virginia
    On my car with electronic dash, it is bright with the lights off & dim with them on. It is always on when the car is running.
    Is your old Prius different? Old mechanical speedometer? :) :ROFLMAO:
    alanclarkeau and Mendel Leisk like this.
  3. Mendel Leisk
    40,508
    I forget what, but I can usually tell. The easiest mistake to make is driving with just the parking lights, then everything but headlights is on, no clue, as long as you're driving in an area well lit with street lights.
    kithmo, alanclarkeau and Prodigyplace like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Because the dash still does light up - unlike in the olden days [remember them] when it got dark, you couldn't see your speedo, so turned your lights on.
    Too many people are unaware of how cars work, too few read their owner's manuals.
    And it will get worse. Back in our time, we learned how cars worked.
    We knew what a clutch did, why there were 3 or 4 gears, how to double-declutch - actually understanding how cars worked. We could strip and repair an inner-tube and reassemble and hand-pump a tyre with the pump we kept in the boot.
  5. alanclarkeau
    7,045
    7,589
    I've been driving on the Motorway with my parkers on lately, particularly if it's a dull day - the parking lights are quite dull, but they put the tail-lights on, I'd rather be seen from behind. Off the motorway, I put it back on AUTO.
    Parkers vs DRL
    My headlights don't have DRLs lit:
  6. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    My parking lights are just the main led but dimmer as well the amber markers being on. Taillights are also on.
    SM-N960U1 ?
  7. fuzzy1
    10,335
    Are your DRLs also the main LED headlights but dimmer? If so, do they have the high beam pattern, or low beam pattern, or something else (like Gen3 no-patten DRLs)?
  8. Frederickdawg
    596
    335
    Low beam pattern.
    SM-N960U1 ?
  9. nownow
    nownow Junior Member
    70
    Pinehurst NC
    Coming from an '08 I accidentally did my first drive (at night) with parking lights and the dimmer DRL mains. It was still far superior to the '08 xenons, which admittedly needed a headlight restoration.
  10. Prodigyplace
    12,398
    11,676
    Central Virginia
    There were some people with 2016 Prius that found their headlights were aimed too high. After they got them adjusted, there were no more issues.
  11. Frederickdawg
    596
    335
    Glad to here that someone else uses this function.
    SM-N960U1 ?
  12. bbunge
    bbunge Member
    35
    33
    Southampton
    Had my dealer check my 2016 Pri2 headlights after getting flashed many times. Was told the lights were within specs. Still getting flashed...
    SM-T380 ?
  13. fuzzy1
    10,335
    Make sure they are clean (road grime can scatter too much light above the intended upper cutoff), then consider lowering the aim a bit yourself.
    Heavier loads in the rear end (of the car, not the front seat occupants :) ) will raise the headlights enough to annoy oncoming drivers. If you frequently drive at night with such loads, considering lighting the loads, or shifting them forward from the trunk to the passenger area, or re-aim the headlights while the car contains a more representative load.
    Prodigyplace and alanclarkeau like this.
  14. Frederickdawg
    596
    335
    I remember back in the day an up/down dial on the dash that allowed the driver to adjust the headlights beam vertically dependent on their load. Or more modern cars currently use self leveling headlights. I think that is required by law for high intensity discharge units sold in the UK.
    SM-N960U1 ?
  15. Tande
    Tande Active Member
    521
    308
    Mich.
    Interesting! .......my 2014 Toyota/Tundra has this feature......very handy when I pull several different trailers (y)
  16. litesong
    litesong Active Member
    371
    122
    Everett, WA
  17. alanclarkeau
    7,045
    7,589
    My 1977 Renault had a knob on the dashboard too for up/down headlights.
    But it also had knobs for the radio - which TOYOTA doesn't believe in except in USA.
  18. Frederickdawg
    596
    335
    Mines got knobs on the radio but they dont light up lol
    SM-N960U1 ?
    alanclarkeau likes this.
