2013 Gen 3 won't start sometimes, no juice, battery not the issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jana26, Feb 1, 2019.
  1. Jana26
    Jana26 Junior Member
    MO
    I posted before about this but can't find it so I'm starting a new one. This problem has been going on since the middle of December. At first I thought it was a problem with the battery being drained but that ends up not being the problem. When it all happens, there are no lights, nothing shows, it's like the battery is either totally drained or disconnected.
    It's been at the dealer more than I've had it in the past 45 days. They can't figure out what's wrong. They've even brought in a tech person from Toyota (Corporate??) to try to figure out what's going on. They think it's a fuse but when they test it, nothing shows wrong. They said they have to test it when it's acting up but it doesn't act up when they have it.
    All that said, here is what it's doing. When I've had it, it starts fine and then, all of a sudden, goes totally "dark". No lights, no codes, no nothing. I've had to jump it (in the front) and then take it back in to the dealer. They've had to jump it to get it into the shop but then it starts fine after that. They've checked wires, connections, the starter button, connections from the battery on, and nothing shows up. They are at a loss.
    Any ideas???
    One thing they told me that might be of importance is once they tried to jump start it at the battery, not the contacts under the hood, but it wouldn't start.
    The car only has 42,000 miles on it.
  2. JC91006
    JC91006 Senior Member
    16,747
    8,552
    Maybe rodents nibbled on the wiring harness. Something not getting power
  3. Patrick Wong
    18,200
    6,500
    I think that you have to become a bit of an electrician, so that you can become comfortable taking voltage readings and interpreting the results.
    It is an important clue that when this happens, it is possible to jumpstart the car at the dedicated jumpstart terminal in the main relay/fuse box; but it is not possible to jumpstart the car at the battery. That calls into question the battery positive terminal connector and cable leading to the main relay/fuse box, the MAIN fuse which is located within the battery positive terminal, and the negative battery cable where it bolts to the body as well as where it attaches to the battery.
    Do you have a digital multimeter so that you can take voltage readings? If you do not have a meter, are you sufficiently motivated to buy one and figure out how to use it?
    #3 Patrick Wong, Feb 1, 2019
    Pluggo likes this.
  4. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    When car is shut off, wait til the next morning and measure the 12v battery at the jump post in the engine bay while engine is OFF and doors are all closed- nothing on drawing power. If the voltage at the jump post are measure below 12.6v, you need the replace the 12v battery.
