Torque pro gen 3 pids
Discussion in 'Gen 3 Prius Main Forum' started by Tiff, Feb 4, 2019.
  1. Tiff
    Tiff Junior Member
    86
    Crawley
    Can someone please help.
    I have torque pro with gen 3 pids downloaded. I can select battery voltage banks 1-14 but they display no data.
    I have checked with a spreadshdet someone had on here but still i cant get them to show my volts.
    Desperatley need to record some battery volts.
    I have torque pro running on 2 android phones and im using a blue elm 327 obd bluetooth device.
  2. Lino
    Lino Member
    61
    Both phones same result, maybe your not doing something right, did you follow the video for setup?
  3. Tiff
    Tiff Junior Member
    86
    Crawley
    Yes checked it over and over again.
    When i test the pid it comes back with an error or no data
  4. Lino
    Lino Member
    61
    Did it work before, if not do you have access to another Bluetooth adapter, mine worked fine on a second gen Prius, and 3rd without issues
    Tiff likes this.
  5. Tiff
    Tiff Junior Member
    86
    Crawley
    Ive sorted it. Its the adaptor. Its a single layer adaptor which isnt good enough. Ordered a prolong one
    Creliandobi likes this.
  6. skydivetoday
    skydivetoday Junior Member
    25
    Marco Island , FL
    2014 Prius v wagon
    Tiff I may have the same problem, what adaptor did you get?
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    See post #5 last sentence.
  8. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    I have had good luck with the OBDlink lx bluetooth. I had the same issue with the elm 327 you did. My OBDlink lx has run well for a year with no issues, but it was a bit pricy. 50 ish bucks.
