Dead battery
Discussion in 'Gen 2 Prius Main Forum' started by ernda, Aug 21, 2006.
  1. ernda
    ernda New Member
    43
    Beverly Hills, CA
    Came back after 2weeks vacation. I made so sure my daughter's Prius would start after two weeks (turned off smartkey, heatlights off, etc) that I forgot to do the same to my car so the battery was dead. I installed the Coastal Tech front power mod a long tiem ago in order to use my little battery charger block that plugs into the outlet. Plugged it in and waited the 15 minutes and nada. I know the bosoter batter y was charged and it even felt warm while doing its thing but zippo as far as starting the car or even lighting up the dash. If I plugged the charger in I could light the overhead light dimly, so juice was going in. I'll try a jump start with my wife's car when I get home from work. Hoopefully the battery is not too far gone.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Sounds like you need to hook up a battery charger to the underhood jump point and let it charge for an hour or so. Hopefully your 12 v battery wasn't damaged
    I still don't understand why Toyota put in something the size of a lawn tractor battery to power up the 12 v side.
  3. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    <div class='quotetop'>QUOTE(jayman @ Aug 21 2006, 06:59 PM) [snapback]307140[/snapback]</div>
    Maybe because all it has to do is boot a computer? High amperage would be useless as there's no cranking required to start the engine.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    yo, richboy.
    bugger off.
    we're all po' down here, you don't wanna hang with us. we're boring.
    _H*
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(hobbit @ Aug 21 2006, 07:55 PM) [snapback]307282[/snapback]</div>
    Just block him like I did, Hobbit. Much less annoying. "Go see the dealer! Go see the dealer!" with variations on Authorised Toyota dealer.
    Eminently forgetable.
  6. kDB
    kDB New Member
    241
    Fenton, MO
    i would not charge it for an hour... hook the charge up to the terminals under the hood, let charge at the lowest setting for a couple minutes (though you shouldn't need to), then try to start. if it does not start then you may have a bigger problem (or the charger isn't working correctly).
    if it does start, unhook the charger, leave the car in ign on mode for about 10-15 minutes. shut it off and let it sit for about 10 more minutes. then try to restart it.
  7. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    It should be noted that completely discharging the aux battery like this isn't too good for the battery - It won't hold a charge as well anymore, and is more likely to die on you in the future (as it holds less of a charge and can be more easily discharged)... you may want to consider replacing it - it's not critical, and the car will work fine once you jump it and leave it running for 15-20 min to charge the battery.
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(iluvmacs @ Aug 21 2006, 09:38 PM) [snapback]307267[/snapback]</div>
    True enough, but the 12 v system also has to operate the interior courtesy lamps, tail lamps, headlamps, radio, coolant pump, brake boost pump, etc. Not so much cranking amps but reserve capacity is important, and that little lawn tractor battery doesn't cut it.
    Ever leave an interior lamp on overnight by mistake? Me too. Do that in a Prius and - usually - nothing happens in the morning when you poke the power button.
    That little lawn tractor battery is pricey too.
    <div class='quotetop'>QUOTE(kDB @ Aug 22 2006, 06:47 AM) [snapback]307399[/snapback]</div>
    I never like to use a high-amp setting on a manual charger. The 2 AH setting for one hour is usually safe. I recently picked up a surplus-clearance "smart" charger/desulphator at Princess Auto for $40 that claims to charge at rates up to 15 AH safely. It will shut down and switch to desulphate once the battery is charged
    At my hobby farm I use VDC Electronics Battery Minder that automatically charge and desulphate the tractor battery and old Ford truck battery. I picked them up at an auction and they work well
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    <div class='quotetop'>QUOTE(jayman @ Aug 22 2006, 10:07 PM) [snapback]307986[/snapback]</div>
    actually i did that once fairly recently (oops!) and it started right up. overwhelming feeling of whoa-that-could-have-sucked.
  10. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(Bill Merchant @ Aug 22 2006, 12:18 AM) [snapback]307333[/snapback]</div>
    I thought I was the only one that got annoyed by the rich boy... yeah he's on my block list. No constructive comments at all. :blink:
    Back to the topic. I agree with jayman. Don't understand why they would put such a small battery. Have you see the price on that little sucker? It's listed $100+.
    I went to a 2 week trip during last year's winter. I had my dad turn on the car at least once per week. I also did left one of the interior lights on one night and the car seems to start fine the next morning.
    I sort of remember reading that someone find a cheaper solution to replace the OEM battery. Was it for the classic or gen 2 Prius? I worry that our batteries will not last as long as the average 12V car batteries.
  11. msnancy61
    msnancy61 New Member
    Wondering if anyone can help me.. I am a new prius owner.. 5 weeks.. just got back from a trip with my kids (one week).. got to my car at one in the morning (late plane).. and the car was dead.. I called AAA and they wouldn't touch it.. would tow it to a gas station.. Found a brave soul to jump start it.. the batteries show they are charged and there was plenty of gas in the car..
    I called my dealer this morning and they told me that this is typical.. that the car can only be left for 5-6 days without going dead.. I couldn't believe this so I called another dealer.. same story... How can this be? I am so upset about this.. How can I get this resolved...
  12. eagle33199
    5,122
    268
    2015 Prius v wagon
    Do you have SKS? if so, you should turn it off before leaving for any amount of time using the button beneath the steering wheel. you'll then have to use the mechanical key to unlock the car... a pain, but it helps keep the 12V battery alive longer.
    You should know that the car can safely be jumped by any normal car or jumper, just like any other car. the 12V battery is in the trunk, underneath the cubby on the passneger side, and there are jumper terminals in the black fuse box on the drivers side under the hood. Either location works just fine. Next time, don't tell AAA what kind of car it is... just tell them you need a jump :-p.
    As for the abttery meter showing full and having gas in the tank, i would hope so! The car has two batteries. a high voltage (HV) battery, and a smaller 12V battery. The HV battery is responsible for powering the electric motor when needed, and is the one who's charge is tracked on the MFD (Multi-function display). The 12V battery acts much like a normal car battery - it helps start the car, and powers the accessories, such as the radio and lights.
    As a safety feature (to prevent drainage), the car dissconnected the HV battery when it's turned off. on startup, the 12V battery reconnects it, and boots the computers, allowing them to then use the HV battery to spin up the electric motor to start the ICE - thus the 12V battery doesn't have to supply nearly as much power as a normal car battery on startup. For this reason, Toyota put in a smaller battery, which has led to much gripping by owners.
    *edit*
    SKS = keyless system. in otherwords, its the thing that lets you keep your keys in your pocket or purse, and unlocks the doors when you touch the handle. And here i thought i was so good at explaining everything :-p
    the reason i mentioned the SKS in the beginning was because it draws a small amount of current from the battery constantly to run (because it's always trying to detect your key). If it's left on, it's entirely possible to drain the battery with it... thats why the OP (original poster) disabled it in his daughters car - to ensure the battery wasn't drained. forgetting to do the same in his car resulted in this thread :-p.
    If you'r going to be gone longer than 2 weeks, there are some additional precautions you can use to protect the 12V battery. if possible, you could hook it up to a battery keeper, something that plugs into the wall outlet and ensures the battery stays topped off. Or you could ask one of your neighbors to come by and drive it for 10 minutes once a week. at the bare minimum, when gone longer than 2 weeks, you should probably disconnect the battery to prevent it from discharging.
  13. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I recommend getting one of the rechargable jumper boxes, indeed, get one with a built in air compressor for added versatility.
    see: http://amazon.com/s/ref=br_ss_hs/103-77458...=0&Go.y=0&Go=Go
    for some examples.
    I don't keep this in my car all the time, but it's a nice thing to have on long trips or when the car will sit, unused, while I'm away on trips.
    That said, by making sure the light switch is turned to the off position (yes, I know the lights themselves turn off when the car is off, but there's still a small power drain if the switch is left in the 'on' position), I always turn off the SKS with the button under the steering wheel, and make sure all doors are securely closed and the car locked. And, knock on wood, I've never had to jump my car even when I've been away for as long as 11 days without the car being started in the 3 years I've had the car. Others have gone up to 3 weeks without a problem. But the SKS, if left on, will definately be an issue and shorten the length you can leave it unused.
    BTW, this is covered in your owner's manual and should have been covered by your salescreature when you took delivery.
  14. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(msnancy61 @ Aug 23 2006, 09:26 AM) [snapback]308175[/snapback]</div>
    Jumping a Prius is just like jumping other cars, but easier. Since it requires less amp compare to a regular car. All we need is enough juice to power up the electronics and some relays. The HV battery is the one that starts up the engine. Why AAA doesn't want to jump your car? Are they scare of the word hybrid? Well, they have many scary years to come.
    I am not sure what your dealer said is 100% true. Some on this site have gone for weeks and the car is fine afterwards. As you read above, the 12V battery is TINY in our cars. To minimize drain on the 12V battery, turn off SKS (button under the steering wheel) and turn light switches to off.
    As for a cheaper replacement for the OEM, I found Autozone's Duralast and Gold-Duralast batteries with 7 and 8 years warranty. Anybody know if these will fit? Autozone listed that they are for 2005 Prius.
  15. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(ScottY @ Aug 23 2006, 09:15 AM) [snapback]308197[/snapback]</div>
    I'd say give one of them a try and let us know :) Worst case they don't fit and you get your money back from autozone (after all, it's false advertising to tell you they work with the Prius when they don't).
  16. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 23 2006, 10:20 AM) [snapback]308198[/snapback]</div>
    Maybe I'll do that when i have some free time next week. If you look under the Gold-Duralast link I posted above, under notes, it said "Battery is vented to outside of vehicle". I know our batteries have vent tube too.
    Anyways, I'll post if I get a chance to try these out.
  17. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 23 2006, 08:55 AM) [snapback]308183[/snapback]</div>
    no, you can still use the remote fob to unlock the car, you just have to push the button on it. you don't need to use the mechanical key.
    rob
  18. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 23 2006, 09:20 AM) [snapback]308198[/snapback]</div>
    Actually, worse case is that it won't have the proper vent tube connection, explosive hydrogen gas will escape into the cabin and cause a fire or explosion thanks to the HV battery!
    This battery is custom and requires an external vent tube since the battery itself is actually inside the confines of the vehicle. It is certainly possible that one might be able to modify the battery in some way to safely vent the gas, but please be careful and be aware of the risks.
    OTOH, if you're successful please take photos of the process and post them up here on Priuschat so others can do the same. Some of us have a 12v battery that's about 3 years old and replacement might be something to think about in the coming months/years.
  19. msnancy61
    Thanks so much for your helpful and insightful instructions.. I can see I am not alone in my disbelief about the battery strength.. I will look for the STS button.. never knew that could be a problem.. I guess I was so used to a typical car that I never considered this possibility.. I did leave the cell phone charger plugged in.. didn't think about it because the light wasn't on when the car was off. Maybe this had something to do with the dead battery.
    Someone mentioned that I might consider replacing the whimpy OEM battery... that it might have been damaged by losing power.. Does anyone know what kind of difference the new one might make?
    The car is an '06 package 3.
    Oh.. I meant to ask.. I live in northern CT.. gets pretty cold here in the winter.. any special precautions I should be thinking about?
    Finally, thank you for your help.. you're a great bunch!!
  20. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(efusco @ Aug 23 2006, 11:04 AM) [snapback]308221[/snapback]</div>
    Yes that was one of the concerns too when I look for OEM replacement. That's why I mention that the Gold-Duralast battery has note saying "Battery is vented to outside of vehicle". If anybody else have some free time on their hands before I do, go over to autozone and check that battery out.
