Possible Monthly install meets. Bay Area-Fremont
Discussion in 'Local Prius Club Main Forum' started by Priusmpg, Jul 1, 2014.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,497
    1,590
    Bay Area
    For the Prius? What happened to your fuel pump and inverter water pump?
    SFO and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,262
    15,506
    Bay Area, California
    2019 Prius Prime
    Hedging my bets;).
    No issues to date, but those pumps are approaching 10 years in service:cool:.
    If I’m going to successfully complete the @bisco challenge and convince the wife that as the miles rack up, we can still use the Prius, I’ll be doing each of these as preventative maintenance :).
    My shop and your video equipment;).
    See you here(y).
    SFO likes this.
  3. NutzAboutBolts
    1,497
    1,590
    Bay Area
    I would just do it when the CEL comes on. I’m still running them :cool:
    Raytheeagle likes this.
  4. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    Good conventional advice:).
    But my luck dictates that when we are on our annual SoCal trip, one would go out and now I’m down there with the parts up north and I’m sure I would be hearing about it:love:.
    But I don’t gamble for the same reason(y).
    SFO likes this.
  5. NutzAboutBolts
    1,497
    1,590
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: Make sure to film it :cool: btw the Prius fuel pump looks easy.
  6. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    I ain’t got the goods:(.
    Professional equipment required and I am a pure noob at videography :cool:.
    I’d be good to finally meet up(y).
    RMB and NutzAboutBolts like this.
  7. NutzAboutBolts
    1,497
    1,590
    Bay Area
    RMB and Raytheeagle like this.
  8. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    Sunday is fast approaching ;).
    Haven’t seen any commitments though:(.
    So I’ll circle back:
    1. @Raytheeagle : Inverter pump changeout
    2. ?
    3. ?
    4. ?
    SFO likes this.
  9. tallassazn
    tallassazn Junior Member
    EGR Cooler and Catch can!
  10. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Hi Ray, I have family obligations on Sunday, not gonna make it. Until next time! (y)
  11. wvs2003
    wvs2003 Junior Member
    @Raytheeagle , if no one else is helping you film and depending on how much time you need for the inverter pump, I can try helping with filming. I got nikon d5500. I usually to photography, but i can try videography
    @tallassazn , if i'm not filming and got free hands, i can help you with the egr and and OCC.
    atm, don't have much to work on my prius, but always wanted to check out this monthly bay area meetup.
    what time do yall usually start and end?
  12. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    I'll add something soon, depending on turnout and participation.
    Weather looks dry, with highs in the 50's.
    Raytheeagle and RMB like this.
  13. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    Since @tallassazn wants to do the egr circuit cleanse, I’m a fan of starting early;).
    Could be as early as 8 am, depending on when people want to arrive:).
    Where would you be coming in from:whistle:?
    I’ll send out a PM shortly (tomorrow morning at the latest) with address and potential times(y).
    SFO likes this.
  14. wvs2003
    SFO likes this.
  15. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    I’ve got everything needed;).
    We’ve done 3 or 4 before at the meetups:).
    Bring the coolant we’ll be good to go(y).
    SFO likes this.
  16. Landon51
    Landon51 Member
    190
    63
    US
    Do we have a time and address yet?
  17. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Yes, we had liftoff at around 8am this morning.
    Pretty sure the PM/conversation went out a couple of days ago, for those that showed prior interest or had signed up.
    Let me see if I can pull @Raytheeagle away and add you to the 'conversation'.
  18. Landon51
    Landon51 Member
    190
    63
    US
    I thought I had signed up, but I've had trouble with this phone where it won't throw an error when it's low power and the "send message" fails
    Which is a long way off saying that I thought I had responded, but I can't seem to find it. 8)
  19. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    The meetup address and related info was forwarded at 11:01am, shortly after your initial post inquiring about such (y)
  20. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    Well another successful meetup completed(y).
    Attendees:
    • @tallassazn with an egr circuit cleanse and oil catch can install (mounted by driver’s headlight)
    • @Grit with an egr circuit cleanse and oil catch can install (went low below the intake manifold:) )
    • @wvs2003 attending for social aspects and sharing his experience experience with egr circuit work and lending a hand in the process
    • @The Critic with social aspects, lending a hand and leaving a very nice shop light for our engine dismantling use:)
    We had a bit of an extended afternoon (and @Grit had a mild heat beat skip) after the vacuum hose to the intake manifold was left off and the P0A0F was displayed:eek:.
    We had Techstream though and worked it out;).
    Until the next meetup(y).
    m.wynn, wvs2003, RMB and 4 others like this.
