Featured Whatever happened to the Prius V replacement, the crossover
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Prashanta, Jan 29, 2019.
  1. bwilson4web
    15,991
    In any product mix graded by the customers (the ones with the gold), there is going to be an optimum performance point and "40mpg" appears to be an optimum. We're Prius and plugin people so 55-130 MPG is what makes us happy. But we are not the average car owner/driver.
    Look back in history to 2001-03 and the Gen-1 Prius. Today, the EPA today lists them as 41 MPG (then 48 MPG) yet Toyota only sold ~55,000 in the USA. Due to some poor configuration choices, we went with an Echo in 2001, then listed at 35 MPG, instead of the local 2001 Prius. Back then, you were expected to be a "green", leaf-looker, bambi-lover, to buy a Prius. That was 14-17 years ago which slightly longer than your "10-15 years"
    Tideland Prius likes this.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Prius 4gen is much closer, that is why I listed the dimensions... ;)
    Bluegrassman likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,004
    8,925
    New England
    Yeah, 40 mpg in city is the minimum requirement for our car. I also need larger cargo and better ground clearance. Thought about used V, but I don't think it has any better ground clearance than regular Gen3. Does it?
  4. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    Very negligible increase in clearance for a v. Gen 3 Prius has 5.3" ground clearance vs Prius v 5.7"
    Salamander_King likes this.
  5. Salamander_King
    11,004
    8,925
    New England
    Thanks. 5.7" is better than PRIME's 4.8", but still not high enough to drive it on rough dirt roads.:cry:
  6. Rmay635703
    Rmay635703 Senior Member
    2,645
    1,667
    Somewhere in Wisconsin
    2013 Chevy Volt
    I drove my Chevy Volt through monument valley with its 3.5” of ground clearance .
    Supposedly only 4wd could enter yet they didn’t tell you that until you were a third of the way along.
    Just had to take care where I put the tires so I didn’t center the cars midsection on a large bolder
  7. Salamander_King
    11,004
    8,925
    New England
    Wow, Volt has only 3.5" ground clearance? :eek: That's as low as some of super-fast sports cars. 10 Production Cars With the Least Amount of Ground Clearance - Bridjit Curb Ramps
    I will never drive my PRIME on any unpaved road. Where I live, even paved roads can be very bumpy from frost heaving and potholes. I have hit the bottom of PRIME many times already.
  8. Tideland Prius
    16,434
    The 3.5" of ground clearance is because of that (plastic? silicon? rubber?) front air dam right under the bumper that GM put on several cars and SUVs in the 2000s/2010s. The "true" ground clearance is 4.7" or basically the same as our Prime.
  9. hill
    8,626
    confirmed.
    My 3⅜“ wide yoyo + adding the 1¼" of actual tape sticking out ... shows that's pretty close .... & some of the plastic underbelly is at least an inch hicher.
  10. Tideland Prius
    16,434
    About 4.5”? This is for the Volt?
  11. hill
    8,626
    yep ... but don't ask me how I know, because @bisco will seriously condemn me for trying/buying every plug-in under the sun, in order to determine what's truly the best of the best. My shame threshold couldn't take it.
    Okay, I admit it, my name is hill, & I am a Prius whore. i went from this ...
    To that ... I'm so ashamed.
    I hope the group can forgive me.
    #31 hill, Feb 22, 2019
  12. bisco
    51,042
    hokey smoke bullwinkle!:p
  13. hill
    8,626
    Come on! I was stuck with a pathetically diminished leaf! Desperate times call for desperate measures !! Can't I get a little forgiveness? The Steeler-ship gave me $1, 950 for the pathetic Leaf ... in trade for the 2018 volt .... come-on! Okay, I understand if you guys won't ever talk to me again.
    #33 hill, Feb 22, 2019
