WTB Gen 3 OEM Fog Lights
Discussion in 'Private Sales' started by The Phoenix, Feb 23, 2019.
  1. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I just purchased a 2011 Prius, that doesnt have fog lights. I am looking for OEM ones so the fitment is better than the after market ones. Thanks
  2. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    I sold my 2015 Prius I don’t have the grill that has a hole for a fog lamps but I still have the projector fog lamps, I will sell to you I am in bay area
  3. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Will they fit in the stock holes like the OEMs That's the whole reason I want to buy some used ones out of a Prius. I am very interested, just would like some more details
  4. Toddwilks
    Toddwilks Active Member
    555
    177
    Whitehouse Station, NJ
    If they don’t take them I will.
    iPad ?
  5. ilovegirls
    ilovegirls Member
    178
    42
    San Diego
    I have OEM foglights. I'm in so cal.
  6. orenji
    orenji Senior Member
    5,887
    3,488
    Go with LED aftermarket you will not be disappointed. Morimoto is a great brand and they will bolt right up. You will need to buy a cheap foglight set off eBay as you will need the wire harness and frames for the fog lights to bolt up to.
  7. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    So you are saying to buy the LED aftermarket lights/lenses and than put those into the stock OEM foglight housing and wiring. Sounds like great plan but there are no cheap OEMs on Ebay at all. Depends on what I can harvest at a salvage yard, thank you very much for the brand name of LED fogs
  8. orenji
    5,887
    3,488
    There should be cheap sets on EBay around $40.00 come with switch, insert frame and wire harness.
  9. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Yes there are some cheap sets but they are aftermarket and I'm concerned about the fitment of the tabs and such
  10. orenji
    5,887
    3,488
    Aftermarket work great. No worries at all. You just want the housing and wires.
  11. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
  12. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Pm me for the projector dog lamp, they are open fit no modification and I use his on them I use an led too before but the light is not good for me but the projector dog lamps is so bright with hid
  13. orenji
    5,887
    3,488
    Well everyone will have a different opinion. I believe HID is old technology now, LED is much brighter. You should research some more so you only do this once. Good luck.
