Should I be concerned with putting a lot of Miles on my Prius
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Feb 26, 2019.
  1. Joe Wall
    Joe Wall Member
    219
    45
    Wisconsin
    I drove 750 miles for a medical school interview and another 1600 miles on another road trip to West Virginia. I am considering driving another 2200 miles. I just got my Prius and am nervous about putting on a lot of miles. It has about 71,000 miles. Should I rent a car and be concerned about the miles? It will be mostly highway miles. I want my Prius to last a long time.
  2. N3K X8
    N3K X8 New Member
    Maine
    That's what it was originally made for. Prius needs little maintenance. I have one that had 230x miles and it still drives like a dream.
    Data Daedalus likes this.
  3. bisco
    50,819
    not sure renting will save you anything in the long run.
    check out the rental costs and see what that works out to in extra prius miles.
  4. Mendel Leisk
    40,245
    I would go for it; that's what it's for.
    We have opposite issue: only need the car sporadically, for crosstown runs at most. We've started taking skytrain when going downtown too, especially for events: parking rates are onerous, and just less stress.
    Be cognizant any time soon would be good for EGR circuit and intake manifold cleaning.
    #4 Mendel Leisk, Feb 26, 2019
  5. bisco
    50,819
    in a gen 2?
    Skibob, Raytheeagle and WilDavis like this.
  6. Mendel Leisk
    40,245
    Uh oh: strike that last paragraph. :oops:
    Skibob, Raytheeagle and bisco like this.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    71k? …a mere baby! …hardly run it! …many, many miles/years ahead! …sit back and enjoy it! ;) :)
  8. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    My 06 gen 2 only has around 60k miles yet does frequent long trips to/from college. It does have a new Toyota HV battery and is on its 3rd inverter pump. Due to age, I plan to change the waterpump, belt, and sparkplugs soon as a preventative measure.
    YMMV
  9. mpg_numbers_guy
    116
    64
    VA
    The more your drive your Prius, the more your hybrid battery is cycled and the happier it will be. Sitting and being driven rarely is bad for a hybrid car.
    srellim234, TomB985 and WilDavis like this.
  10. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    3rd inverter pump in 60k? o_O
  11. Mendel Leisk
    40,245
    Typo on the miles??
  12. Graeme1949
    Graeme1949 Member
    51
    47
    Atlanta, GA
    I would say don't worry about it. I have a 2004 Prius (original owner) and have over 190,000 miles on it. More than double what I had on any American car in the last 50 years. Just had its first brake job at the 190k service. No problems with the main battery (the high voltage one.) It's still my daily driver, I just don't drive as much now. (Retired.)
    -Graeme-
    2004 Prius with >190,000 miles.
    Sent ?.
  13. Mendel Leisk
    40,245
    I've read each charge/discharge is akin to a life, and there are a finite number of lives, around a thousand max, for NIMH batteries.
    Lifespan – Battery Universe Blog
  14. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Do the research and the preventative maintenance, check and change the oil often (whatever that means to you).
    You will be fine (y)
    Raytheeagle likes this.
  15. Joe Wall
    Joe Wall Member
    219
    45
    Wisconsin
    2009 toyota prius touring so yes gen 2
  16. Joe Wall
    Joe Wall Member
    219
    45
    Wisconsin
    Why?
  17. Joe Wall
    Joe Wall Member
    219
    45
    Wisconsin
    $170 to $200 depending on car. Will be going from Wisconsin to Alabama so much warmer and not sitting in cold
  18. mpg_numbers_guy
    116
    64
    VA
    That's true, but it's also harmful for a battery to sit for a long period of time. (n)
  19. padroo
    padroo Senior Member
    2,763
    2,251
    I worked with a guy who always rented a car on trips. He said he ran the hell out of them and if they broke down just call up the rental company and they bring you another one. It does relieve the stress on a trip. Your call, your money. You probably won't be gone long enough to have any problems with your car not being used for a few days or weeks.
    WilDavis, Skibob and Mendel Leisk like this.
  20. Mendel Leisk
    40,245
    No EGR (Exhaust Gas Recirculation), and PCV (Positive Crankcase Ventilation) comes off top of valve cover, less clog prone, on Gen 2.
