Toyota's Engineering Choices on Gen IV and Prime
Discussion in 'Prime Technical Discussion' started by PiPLosAngeles, Feb 28, 2019.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Because of a long-running ordeal with my 2018 Prime, I've discovered that Toyota intentionally designed Gen IV Prii (Primes included) to reduce the output of the DC-DC converter when the car is in drive from 14+v to ~12.5v. We also know that Toyota has been moving to smaller wire in their harnesses to conserve weight. I am not an electrical engineer, so I'm asking somebody with more knowledge to help me understand Toyota's overall strategy with these moves.
    My understanding is that lower voltages require higher currents for the same power demand. If the 12v system has a 1,000W load (A/C compressor, headlights, blower, interior lights, 12v accessories, etc.), the DC-DC converter has to put out 71 amps at 14v, or 80 amps at 12.5v. Either way, the DC-DC converter has to draw 1,000W + whatever the conversion losses are from the battery and put out 1,000W.
    It is also my understanding that the power carrying capacity of a wire is determined by amperage, not voltage. In other words, a 20 gauge wire can carry 10 amps no matter the voltage: 120 watts at 12v, 140 watts at 14v, and 90 watts at 9v.
    If all of that is true, it means that for the same load, decreasing voltage requires larger wire and isn't saving any power (1,000W is 1,000W). If Toyota's strategy is to enable the use of smaller wire in the 12v system, shouldn't they be boosting the voltage of the 12v system rather than decreasing it? I'm not understanding the logic of dropping the voltage when the car is driving. What is to gain when there's everything to lose?
    kevin.c likes this.
  2. schja01
    schja01 Senior Member
    1,831
    1,220
    Chicagoland
    2024 Prius
    Limited AWD-e
    Ohms Law baby,
    I worked for a Wire and Cable outfit before I retired.
    I suggested that wire could be made lighter by making the conductor tubular.
    Current is carried for the most part by the skin of the conductor so I figured that
    would work. The suggestion never went too far. Maybe they waited until I retired
    so as to no have to pay me royalties on the idea? :)
  3. Prodigyplace
    12,554
    11,773
    Central Virginia
    I do not think tubular conductors work well for DC voltages & currents.
    Tubular conductors are used everywhere as high frequency transmission lines for radio, TV, & microwave. Some use rigid lines that look like plumbing and there are lower cost flexible options.
    The "bullet" shown in the first image is used to connect the center hollow conductor & to keep it spaced away from the outer conductor.
    #3 Prodigyplace, Feb 28, 2019
  4. padroo
    padroo Senior Member
    2,763
    2,252
    Toyota saves money by going to a small gauge wire and everyone is doing it. They tell you weight but money is their main concern. Just my opinion.
    E X I = P so voltage time amps equal the power used and is expressed in watts.
    I think Toyota has some very smart engineers and there may be reasons unknown to you why they do what they do.
    Why does this particular information bother you?
    DC voltages have no frequency.
    Prodigyplace likes this.
  5. PiPLosAngeles
    1,551
    724
    Because moving to smaller wire and decreasing the voltage of the 12v system means I can't use the 12v power outlets to power my laptop. When a large part of your job is traveling around with a laptop, that sure puts a major usability ding in the car. Any device that cuts out at 11v is limited to 5 amps in the Gen IV. A device that cuts out at 10v is limited to 8 amps.
  6. PiPLosAngeles
    1,551
    724
    Ohm's Law is what makes their choice seems bizarre. Decreasing voltage AND wire size at the same time is a double-whammy on the capacity of the system.
  7. Prodigyplace
    12,554
    11,773
    Central Virginia
    Not the answer you want :(
    Low Voltage in Rear Power Outlet | Page 7 | PriusChat
  8. padroo
    2,763
    2,252
    I think the power points are only rated at 10 Amps so that would be 10 amps times 12 volts would only be 120 watts and at 14 V that would be 140 watts. How much power does your computer draw?
    I doubt the police use the power points for their computers and equipment. You will probably have to install a dedicated outlet rated for more power to do what you want.
  9. PiPLosAngeles
    1,551
    724
    75W. The outlets cannot put out more than about 65W and stay above 11v. At 75 watts the voltage drops below 11v which triggers the low voltage shutoff on the inverter. I confirmed with all the major manufacturers of sine wave inverters that they do NOT make an inverter that doesn't have a low voltage cutoff.
    The reason I didn't start off with a dedicated, hard-wired inverter is because the owner's manual AND the outlets themselves say they'll support 120W at 12v. That specification is false. If you stick strictly to 12v, the outlets are limited to about 25 watts and 65 watts for 11v.
    #9 PiPLosAngeles, Feb 28, 2019
  10. padroo
    2,763
    2,252
    #10 padroo, Feb 28, 2019
  11. Prodigyplace
    12,554
    11,773
    Central Virginia
    According to this post, they would need to run a line fro the ECU..
  12. PiPLosAngeles
    1,551
    724
    Thanks. This is likely the route I'll go to avoid trying to run wire through the firewall myself.
  13. PiPLosAngeles
    1,551
    724
    I appreciate all the responses trying to help, but I'm really hoping for some insight into Toyota's choices here. Does anyone know what advantage is gained by reducing the voltage of the DC-DC converter? It seems like you'd want a device with a 100 amp limit to operate at the highest voltage possible to maintain efficiency, maximize capacity, and reduce wiring needs.
  14. padroo
    2,763
    2,252
    Tesla's model Y will eliminate the 12 V Battery.
  15. PiPLosAngeles
    1,551
    724
    They're gonna have to have something to supply 12v (or 120v AC) to accessories if they want to sell cars. I don't think people will be willing to give up being able to charge and use device in their cars to buy a Tesla.
  16. Prodigyplace
    12,554
    11,773
    Central Virginia
    All you would need is some sort of DC voltage regulator off the traction battery.
  17. PiPLosAngeles
    1,551
    724
    That's what Toyota has now, and that's what they flubbed on Gen IV. Technically, that by itself wasn't a flub, but allowing the combination of smaller wiring and reduced voltage was a flub.
  18. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    Vehicles have cut voltage on the 12v circuits for years.
    My 2001 Honda Insight does it and so does my Cobalt.
    The car attempts to keep the 12v battery at a low float voltage once the car thinks it’s charged up. This improves economy and makes the battery last longer (my Cobalt has a 10 year old battery that works fine)
    The engineers likely could care less about the power outlet performance but thankfully I’ve never had a problem :0
  19. Prodigyplace
    12,554
    11,773
    Central Virginia
    Toyota has a battery too though.
    Toyota is actually using an inverter to to DC -> AC -> DC
  20. padroo
    2,763
    2,252
    Eliminating the 12V battery does not mean eliminating the 12 V system. Through electronics they can make the DC voltage anything they want. Running small diameter wires will create a voltage drop across any wire with a large load. All wires have voltage drops anytime current flows but the trick is sizing the wire for the intended load. There are wire sizing charts that tell how much voltage drop is acceptable at any given length, voltage and amperage.
