Misfire continues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Theman414, Mar 2, 2019.
  1. Theman414
    Theman414 Junior Member
    Dubuque IA
    Okay so work done so far, all injectors changed, coils swapped with no change, spark plugs changed, entire intake system cleaned, compression check, coolant system pressure test, fuel pressure test, 12V battery changed. Now the car is still throwing P0301, P0304, and P0300. Now what did change that I noticed was I put the car in Drive and the idle sped up quite a bit before leveling out. Going down the road if it starts to misfire I can put the gas to the floor and it stops. It’s only when I turn right or at the low end of the RPM’s. What am I missing please help
  2. orenji
    orenji Senior Member
    5,886
    3,487
    You cleaned the intake, does that mean the EGR cooler as well?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Is the coolant level stable?
  4. Muneeb
    Muneeb Junior Member
    22
    SURREY
    Business Edition
    Sounds like a EGR valve, better to clean the EGR Valve and EGR Cooler and this should resolve the issue. If problem persist try changing the EGR Valve. As you have done lot of work its better to put the new EGR Valve and clean the EGR Cooler and pipe.
    Granny hill hot rods likes this.
  5. Granny hill hot rods
    Corinth ms 38834
    I have the same issue misfire on cyl 3 ,change the plugs and coil packs all 4 not bad looking for 226000 miles,,still did it ,so changed the egr valve new toyota part,cleaned the intake tube ,but didn't clean the egr intercooler like a big dummy so pull all back apart it is completely stopped up solvent will not even run through it ,so letting it soak over night
    ,just wondering how far back the system must I go I cleaned the tube that intercooler attached to ,maybe this will work ,btw only time it misfired is pulling a hill around 70mph,
  6. Mendel Leisk
    40,495
    How many miles on it?
  7. Granny hill hot rods
    Corinth ms 38834
  8. Granny hill hot rods
    Corinth ms 38834
  9. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Blown head gasket
  10. Granny hill hot rods
    Corinth ms 38834
    Not running hot ,not losing coolant idk might be thanks
    Only misfired for a few seconds then runs fine the check engine light flashes I let off the gas it starts running great again?
  11. Mendel Leisk
    40,495
    And clogged or near-clogged EGR cooler.
  12. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Once you get the cooler, that’s the extent of the plugging ;).
    Use a pressure washer and it’ll get the deposits right out:).
  13. Mendel Leisk
    40,495
    Oxi-Clean solution soaks, if you want to take the slow road. About half a dozen, hour long soaks, and run a thin wire through if needed to get it through.
  14. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I bought a tub of the stuff and it just never cuts through a cooler that is packed:cool:.
    But 1700 psi does ;).
    Just did my 10th cleanse a couple of weekends back when the Bay Area meetup was in town:).
    3 at once in under 15 minutes they were clean and ready for service(y).
  15. Mendel Leisk
    40,495
    Yeah I think it depends on degree of clogging.
    That sounds better than ultrasonic cleaning, and morereadily available.
    Different horses for different courses: if you're like me, clean the EGR on a whim, at 50K miles lol, Oxi-Clean gets you were you want to go (John Candy quote).
    Raytheeagle likes this.
  16. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    For the above, pressure is the solution;).
    I soaked one for a couple of weeks with hot Oxi clean and ended up giving up and hitting it with the pressure washer:).
    The setup is the most time consuming part, so if you don’t have one, use the local self serve car wash and theirs will do just fine(y).
  17. Granny hill hot rods
    Corinth ms 38834
    You were correct clogged EGR cooler ticket to the carwash cleaned it out installed everything back 600 miles so far issue solved thanks
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Maybe if enough people do the pressure washing routine @Mendel Leisk will give up the Oxi Clean for the next round:).
    I guess if there will ever be a next round that is(y).
  19. padroo
    padroo Senior Member
    2,763
    2,251
    When you put the gas pedal to the floor WOT, the ECM goes full rich and takes no information from the O2 sensor, check it out.
    You need to get hooked up to a scan tool and check your O2 sensors.
    I didn't see the MAF sensor cleaning on the list?
  20. Granny hill hot rods
    Corinth ms 38834
    Update on misfire 3 cylinder EGR valve intercooler was completely stopped up took it to the car wash pressure washed it cleaned it out installed everything back 600 Mi no misfire I believe the issue is solved thanks for all the help
    Mendel Leisk and Raytheeagle like this.
