PCU coolant at low level
Discussion in 'Gen 4 Prius Technical Discussion' started by ykbj, Mar 6, 2019.
  1. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    In light of the event of Engine coolant inside catalytic converter | PriusChat
    Is it normal that my PCU coolant is just right above/almost touching the low level line. My Prius is only at 17k km and it's less than a year old.
    Part #7
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    I think the dealership only fills it to the low level line at cold. If they were to fill it to the top, it would overflow when hot.
    So, as long as it isn't empty. Keep an eye on it.
    kithmo likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Mine is a tiny bit below FULL - but the engine is hot - I've only been home a little while after a ½hr drive.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It should be between LOW when cold and FULL when hot, that's why it has two level indicators.
    If it's under LOW then it needs topping up (top up to Low level when the engine is cold), if it's over FULL then it is overfilled, if it's between then leave it alone.
    alanclarkeau likes this.
  5. alanclarkeau
    7,045
    7,592
    I've been out for most of the day - just looked up the manual:
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    OK, but according to that, when the engine warms up, the coolant will be over the full level.:unsure:
  7. alanclarkeau
    7,045
    7,592
    Could be - but there is heaps of space above "FULL" for it to expand. Not sure if it expands as much as the engine coolant - you can touch the top of the inverter (just), you're not going to touch the engine when it's hot.
  8. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    the diagram shows the engine coolant reservoir, but where is the reservoir for converter coolant?
  9. ChapmanF
    18,223
    See callout ⑦ in the illustration in post #1.
    If it is low, go ahead and top it to the FULL line. At operating temperature it doesn't expand as much as kithmo thinks.
  10. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    If the engine coolant reservoir is a little bit below the full line, when the engine's cold, should I top it off to the "B" line?
  11. ChapmanF
    18,223
    Only as one step in the process of refilling an empty system. It should end up at the FULL line once it has traded places with the air in the system.
  12. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Ok, thanks.
  13. a2058
    a2058 Junior Member
    55
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I overfilled it when I changed the coolant on the PCU by about 1/4 inch over the full mark with everything cold, that was 40000 miles ago. There it sat, never overflowed and it’s been totally ok.
