Excessive oil consumption. Issue resolved by Toyota.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ctt, May 24, 2016.
  1. douglasjre
    douglasjre Senior Member
    2,090
    698
    Null, NL
    What wt oil was used?
  2. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    The recommended is 0w20 here in the UK but may be heavier in hotter climates
  3. Lambert
    Lambert Junior Member
    Los Angeles
  4. Lambert
    Los Angeles
    My friend has a Prius with 83,000 miles on it and it started burning out...a quart every 700 miles approximately. Purchased used at 78,000 with a extended warranty. Was given the same options on solution. Her issue was not resolved because she is a single mom and cannot afford the extra expenses. Adding oil is the only solution. My family has 3 prius's, a 2012, 2014 and a 2016...leaves me thinking if we made a bad purchase.
    Preeeus likes this.
  5. Mendel Leisk
    40,493
    Anyone ever think how boring this site would be, if Prius didn't burn oil like there's no tomorrow, clog their EGR systems, barf oil into the intake through PCV hose...
    RMB, Preeeus, CR94 and 5 others like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    All we’d have to talk about is bad 12 volt batteries:oops:.
    And that takes many years if looked after well(y).
    RMB, Montgomery, SFO and 1 other person like this.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    There would still be the 600, 700, and 800 mile club posts to look after. Speaking of that, mine is giving me indications that an incursion into the 700 club might be a distinct possibility in the coming weeks. Significantly higher initial mileage indicated on the HSI on this tank. We shall have to see.
    Mendel Leisk and mjoo like this.
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I remember before I was even a member here when the 3rd generation was still pretty new. There wasn't all these head gasket and oil consumption posts. The good ole days! :)
  9. orenji
    orenji Senior Member
    5,886
    3,487
    Before one gets the oil issues, one should do oil changes at 5K miles, use thicker oil then 0W-20, Clean your EGR around 100K miles, drive easy, not like you stole it. Change your coolant at 100K, most important check your oil at each fill up.
    Montgomery and Mendel Leisk like this.
  10. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    Being a Mechanic, I've been suggesting "proper" preventative maintenance since day one. Most here won't listen.
    RMB, Montgomery, orenji and 1 other person like this.
  11. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I did all of these things and my Prius v still stated to burn oil unfortunately :(
    Preeeus and Mendel Leisk like this.
  12. frodoz737
    4,509
    2,430
    33
    Engines wear, some faster than others. The user controls use, monitoring and maintenance.
    Montgomery likes this.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Out of all the cars I own, the Prius has been the most reliable and predictable. But I have to add, there is a website called "Priuschat" that has this awesome community of people who pass on all of the issues they have had with their cars and show solutions to them! This alone, has made me want to keep my car as long as possible. I know what to expect to happen to my car in the coming miles................and I know where to go to get help!!
    RMB, orenji, FnRedPrius and 2 others like this.
  14. orenji
    5,886
    3,487
    What was the miles on your Gen3?
  15. Peter123
    Peter123 Active Member
    131
    128
    It is almost time for another oil change and the oil level is down about 3/8" which I think is about 1/3 of a quart. Before the clean out I would have put in 3 or 4 quarts by now to keep oil in the crankcase.
  16. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Raytheeagle likes this.
  17. Preeeus
    Preeeus Member
    258
    60
    Did you also change oil viscosity, or are you still using 0W20?
  18. Peter123
    131
    128
    I'm still using 0w20 Mobil One.
    Preeeus likes this.
  19. Peter123
    131
    128
    Preeeus likes this.
  20. Preeeus
    Preeeus Member
    258
    60
    Did you use the Synthetic or Regular Motor Medic motor flush?
