Carbon Fiber Baby Rattle
Discussion in 'Prime Main Forum (2017-2022)' started by Stefan Battermann, Mar 17, 2019.
Tags:
  1. Stefan Battermann
    Stefan Battermann New Member
    I bought a 2018 Prius Prime and I'm very disappointed by the quality control issue which I've uncovered. As many if you in know, the liftgate on the hatch of this vehicle is made of carbon fiber to offset the weight of the battery in the back. When the liftgate is opened or during hardish cornering it sound like a giant baby rattle. I suspect that this is the result of remnants from drilling into the carbon fiber to attach pieces to it. I would have thought Toyota would have done a better job in QC on an issue like this. Is anyone else seeing the same issue?
  2. a_gray_prius
    2,927
    783
    IL
    Mine is pretty solid sounding - no rattle.
  3. schja01
    schja01 Senior Member
    1,827
    1,217
    Chicagoland
    2024 Prius
    Limited AWD-e
    Not with mine.
    TGrracie likes this.
  4. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Ditto with ours. Solid with no rattles.
  5. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    hmmm... I don't think this is a normal occurrence. I've had no problems with rattles.
    Did you buy your 2018 new? If not, could there have been some undisclosed repair work done?
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    No rattle with my hatch.
  7. bisco
    51,523
    welcome!
    should be under warranty. every once in awhile, a disgruntled worker will leave an empty beer can in the body somewhere
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,145
    Tampa, FL
    Welcome to Prius Chat! No rattles here, either. I'd try taking it back to the dealer. It's probably an easy fix and I'd think the warranty would cover that.
  9. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    no rattles neither. May be you can try to remove all personal items from the car and see if it still rattles. Sometimes those items create noises, or, it is simply the license plate mount?
  10. Stefan Battermann
    Thanks for the feedback. I did a closer inspection and found the source of the issue and it is glass shards and not carbon fiber bits which are the culprit. It looks like the rear window broke and was replaced without anyone bothering to clean out the glass shards from the liftgate. Remember that this is a brand new card. I'll be having a few words with the dealer tomorrow. Any thoughts about what they owe me for this?
  11. DavidA
    2,342
    1,818
    Chicago western burbs
    No rattle on my hatch either. 2017.
  12. eskudo12791
    eskudo12791 Junior Member
    22
    Virginia Beach
    I would look into some type of dimished value adjustment. Depends on how far you want to push it, they sold a new car, with damage that wasnt expressed to you.
  13. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    You might not get anything from the dealer. They may say that it happened at the port or regional preparation facility. Not their problem. At best, you might get a free loaner while they clean out the glass bits.
  14. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    Sorry to hear your unpleasant discovery on the brand new car. It is hard to say what the dealer will do for you. Did you check your document to see if it was disclosed anywhere? I am not even sure in your state, if they are required to disclose such repair before selling the car as "NEW". I think law differs by states.
  15. a_gray_prius
    2,927
    783
    IL
    This is the most useful insight here. You probably have some leverage by leaving poor reviews on the dealers business listings, but it's likely not so effectual (though if you do, your case is made much stronger by including lots of photographic evidence).
    Some reading:
    What Happens When The Dealer Wants To Sell You A Damaged New Car?
    This appears to be legal advice for your state:
    I Purchased a Damaged Car. Do I have a Claim for Consumer Fraud? Do I need a consumer lawyer to sue the dealership? :: Eatontown, New Jersey Lemon Law Lawyer The Law Office of Jonathan Rudnick LLC
    Salamander_King likes this.
  16. bisco
    51,523
    there was a problem with early primes and cracking rear windows, they had to redo the hatch in some way. held up production for awhile.
    but yours may simply have been an accident. they should certainly clean it all up.
