Cheeeeep 0W20 Full Synthetic and Oil Filter....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Launch Vehicle, Mar 19, 2019.
  1. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    For some time now, Walmart has been selling their Super Tech house brand of Full Synthetic 0W20 motor oil and oil filter (10358). A 5 quart jug retails at $15.98 ($3.20 per quart!) and the oil filter - which looks exactly like Frame's Extra Guard CH10358 and may well be made by them - goes for $2.97.
    Two Question: Any guesses out there as to who REALLY manufactures this "full synthetic" oil - and - would you consider using it (together with its half-price filter) if it made 5000 mile oil change intervals more "practical"?
    The underlying reasoning here is that frequent oil changes (more frequent than, say: 10,000 miles) may help to reduce the gunk recirculating thru the EGR valve and Intake manifolds....
    Folks, what say ye?
  2. Grit
    Grit Senior Member
    6,414
    4,182
    Wilkes Land
    It’s not formulated with detergents and anti wear additives for protection. But It does meets standard lubrication, heat and viscosity benchmarks.
  3. Prodigyplace
    12,396
    11,676
    Central Virginia
    orenji likes this.
  4. Elektroingenieur
    2,515
    3,277
    Three Touring
    At least for one version, the Safety Data Sheet (PDF) names Warren Distribution, Inc., as the supplier.
    I’m not sure about the filter, but the engine oil packaging shows the American Petroleum Institute certification marks, and the product is listed in the EOLCS database as meeting Toyota’s ILSAC GF-5 requirement.
    Merkey and FuelMiser like this.
  5. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    True of WalMart synthetic in much, but not all of the US. Walmart uses other suppliers in some areas. It is good oil. (Grit is confused.) That company is also known as Warren Performance Products or WPP.
  6. Mendel Leisk
    40,493
    I get Toyota 0W20 bulk through my dealership pretty cheap. For a long time it was $4.50 CDN per litre, then recently a bit more: $4.90.
    Still, a few bucks more or less is trivial.
  7. orenji
    orenji Senior Member
    5,886
    3,487
    Toyota filter $5.00 and Mobil 1 0W-40 - 5 quart jug for $25 at Walmart.
  8. Prodigyplace
    12,396
    11,676
    Central Virginia
    Why 0W40 instead of the recommended 0W20?
  9. ASRDogman
    ASRDogman Senior Member
    7,125
    3,721
    super tech oil is really cheap oil. Several years back I seem to remember reading an article about it that it may be
    recycled oil. But I can't confirm this.
    But, the price difference between know real oil, is worth the $2-3 extra cost.
    $25-27 for Castrol or Mobil 1 syn. oil. Genuine Toyota filter can be had on ebay for about $3.75 when you buy
    5 or 6 at a time. That's what I did.
    The oil and filter are the most important item for your engine. WHY risk a $5000 plus engine repair/replacement
    to save a few dollars????
    Grit, orenji, RMB and 2 others like this.
  10. orenji
    5,886
    3,487
    OW-20 is too thin. It’s recommended only to satisfy US regulators to meet CAFE standards. Thicker oil is recommended in other areas around the world within the Prius manual.
  11. Grit
    Grit Senior Member
    6,414
    4,182
    Wilkes Land
    CR94 would say you’re confused like me also.
  12. ASRDogman
    7,125
    3,721
    Well, I know it's crap oil, that' "I" am not confused about. :)
    Grit likes this.
