Shaking/shuddering Prius after standing still for 5 days
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by R-P, Mar 23, 2019.
  1. R-P
    R-P Active Member
    804
    288
    Netherlands
    First off, I think it is solved as I haven't seen/felt it since. Certainly not nearly as violent. But I still wanted to mention it to see if someone had some insightful comments.
    After having been off to Disney Paris for 5 days with a Hyundai 7 seater with 6 people, I returned to the Prius, put the key in and pressed the "START" button. It came to life violently: it was shaking on its wheels. It became less violent after a few seconds, but I still turned it off quite fast.
    Two details probably worth mentioning:
    (1) I had some dashboard parts lying loose in the car, as I had put the aftermarket JVC radio from the Prius into the 7 seater and was in the process of putting it back and needed it to power ON to make sure I connected everything correctly before putting all dashboard parts back. I am fairly certain it would not have seemed this violent (but still very much noticeable) if it had all been attached properly.
    (2) the car was on parent-in-laws driveway with the nose slightly higher than the boot due to a small incline.
    I measured the oil after turning it off and even at the incline it was still above the minimum, but I added half a liter just to make sure.
    I have left the car untouched for almost 10 weeks some years back and it didn't exhibit anything like this back then.
    Ideas welcomed.
  2. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
    Any large amounts of water getting into the engine compartment while you were gone (big downpours, melting snow, etc.).
    My nephews washed my car once (I offered to pay them $20). They ended up getting so much water all over that some ended up leaking down past the coil(s) and caused a very violent misfire on starting. It only lasted a second or two and never returned (three or four years ago).
    R-P likes this.
  3. padroo
    padroo Senior Member
    2,763
    2,252
    This makes sense.
  4. bisco
    51,843
    any chance you started it before leaving, and shut it down before it finished warming up?
    R-P likes this.
  5. R-P
    R-P Active Member
    804
    288
    Netherlands
    I can't see how water got into the engine-bay, but misfire does sound like a reason for it to make such noise.
    And I can't rule out that I turned it on while taking the radio out. So the 'not-warming-up' could also be true. Would this possibly cause similar efects? How?
  6. bisco
    51,843
    unburned hydrocarbons can remain in the intake manifold, and detonate on the next start
  7. DrBrian99
    DrBrian99 Junior Member
    Charlottesville, VA
    I am having a similar issue.
    After plowing through some snow drifts on my way to ski, the engine got very loud, the red triangle came on and display flashed problem.
    I had just reached my destination, so I shut the car down and went skiing.
    I thought the car had overheated due to snow packed in front of radiator.
    I returned to the car after 2 hours, cleared the snow from radiator (it was completely blocked) and turned on car. The engine was still loud, the triangle was still on, but I still decided to drive home (probably not so smart, but it was 0 degrees F, and I didn't want my wife to drive an hour to rescue me).
    I drove down the mountain for about 10 minutes, and the loud engine noise was going away. I stopped to take off the tire chains and when I restarted the Red Triangle (of death) wasn't lit anymore, the engine was now quiet when accelerating, but was noisy and vibrating when drifting.
    This continued all the way home.
    This happened Sunday, feb 14. Today, Feb 15 I started the car, and it was loud and vibrating.
    My wife was outside and I asked her later if it sounded loud, and she said no. It seems to be a vibration that makes it sound loud inside the car.
    I took off the air filter and there was water below (before) the filter, and I'm assuming water got into other places.
    Each time I drive it seems to vibrate less, or less intense. It's most noticable when coasting, and the acceleration seems blunted too. I'm used to being able to chirp the tires a little with full acceleration from at dead stop.
    What's the best way to get the water out of the system?
  8. R-P
    R-P Active Member
    804
    288
    Netherlands
    Just to mention it did it again after standing still for 2 weeks (with some torrential rainstorms during that time...).
    Not so scared anymore, since I know by now it's just a few seconds. And then a few seconds of hearing the rust being scraped off the discs (we have 4 in Europe :D) by the pads.
    Long version of the story: we did several >1000km one-way-trips with the Prius instead of the V70 Volvo (way more trunkspace, but odly enough less legroom in the back) because of the aircon evaporater AND the condensor were broken. This was determined by a specialised AC company, (sniffer went berserk inside the car).
    This included our family of 5 going to Savona (>1000km) for a cruise and subsequent little trip through Italy in blistering >40C (110F) heat. Also staying at a hotel without AC: we've had a guy looking like an ax murder walk into our locked motelroom in the middle of the night in Canada, but this night in Italy was easily the worst night in a hotel of our lives... (Guy drove an old Firebird, hair down to his butt and all around nice guy. Motel run by a couple. Wife had rented us the room and given us the key, ax-murderer-guy came in late and found husband behind reception, husband didn't know our room was taken and assumed key just got misplaced so gave him the spare key. He turned out to be as starteled as us, finding people in his bed :ROFLMAO:)
    I don't like dealers, so do most my work on the cars myself. Condensor is fairly easy. So I replaced it by a poorly made version that didn't fit properly and replaced it again for one that DID fit (but company refused to refund the first because it had been mounted). 100$ down the drain. Evaporator is at one and a half day's work at a stealer (so probably >1500$ on a 4000$ car? ) so I assumed it would take me 3-4 days with no way to do the complete dismantling of the dash (including steeringwheel and airbags) in a garage/with a roof over my head. So I had been procrastinating this for years and years.
    Electronic failure of the CEM (Central Electronics Module) of the Volvo, causes the car to go into limp mode (including no dash/speedometer, horrible clunky shifting of automatic gearbox, etc.) when temps are over 30C (75F). Repaired myself, but repair didn't last. Found a pro, he replaced the flash memory and car works beautifully again. Discussed the evaporator procrastinating and he said he'd never heard of an evaporator dying on this car so adviced to have it retested. Found local AC company that works for a lot of dealers to do a test if evaporator was actually broken. Turns out they had Volvo posters hanging around the workshop :D and found no leak. Refunded the 35$ test charge if I had them fill the AC (120$, Volvo needs 1000grams of coolant, I think lot of other cars only use half...). Best guess is that the first time the condensor was leaking so much that the 'sniffing'- chemical escaping was sucked up inside the engine compartment and blown into the car's cabin and thus picked up by the sniffer. Very unlikely that a specialist would make this mistake and not consider this, but the most likely scenario. So I drove without AC for years for no real reason. Cars with AC don't have their CEM's failing as often as it gets cooled below 30C by the AC (BTW, Canadians occasionally get this error in the winter when the heat is turned on to max inside the car).
    Prius struggles with the 5 of us more and more, I need the lift kit for the rear :eek:. Kids still growing, so total weight keeps going up...
    And this time we needed the bench for the dog (instead of her lying in the passenger footwell for small trips), the top box and a bunch of food (gluten free kid inside). So really glad the Volvo had its AC fixed. And the reason for buying an AWD was because our previous car (Ford Mondeo with a broken AC, fixed for 600$, broke again few month later, supposedly a different part, we stopped dumping money into it then and there) got stuck on the Danish beach before I realised all other cars on there were Audi Quattro's and Subaru's. So 18 years later I could finally use the AWD on Danish beaches... Too bad they were all so smooth that even large 2wd campers drove on there, but I carefully found some pieces of beach where the AWD had to intervene :p
    Volvo also has automatic leveling. Mechanical, but still works fine.
    So that's why the Prius was down for two weeks.
    #8 R-P, Aug 23, 2021
  9. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Is it worth doing a leak down test to rule out headgasket?
  10. R-P
    R-P Active Member
    804
    288
    Netherlands
    It runs fine after a few seconds, so not really worried. But do you think I should? It does use some oil, but I thinks that's like 1 liter per 3000km (roughly one quart per 1800 miles?). Not ideal but no reason to pull the entire engine just yet imho, but if this is linked, I might try to do the leakback test.
  11. adrian-gregory
    61
    40
    GAIA
    Business Ed. Plus
    Only takes a few seconds to get rid of any water in the piston area and for normal running to resume.
    A leakdown test should not be hard to perform and if all is good that’s one possible thing off the list.
