Service advice for Prius Prime after 2 year warranty ends
Discussion in 'Prime Main Forum (2017-2022)' started by ridprius, Mar 30, 2019.
  1. ridprius
    ridprius Junior Member
    Stamford, CT
    Hey all, I was wondering how often you guys take your car in for oil change and where you go if you don't go to Toyota dealership? Coming up on needing my first servicing at 27k miles without having the complimentary 2 year warranty and was looking for advice. I am sure they probably tell us to come sooner than we need to, but I also want to make sure my car continues to drive like new so any advice you have to give would be appreciated!
  2. schja01
    schja01 Senior Member
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    The warranty is 3 years bumper to bumper and 5 years power train the complementary service is 2 years. You probably want to have it serviced according to toyota’s recommendations to protect those warranties.
    bruceha_2000 likes this.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Tire rotation every 5000 miles
    Oil change every 10000 miles
    Air filters every 30,000 miles
    Any mechanic or DIY can do that.
    At 120,000 miles, see the dealer again.
    HPrimeAdvanced likes this.
  4. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    Are rock chips considered "bumper to bumper" the primes paint is soo thin that even the smallest rocks are enough to chip off the paint.
    I miss the 60's paint quality. These water base paints are too thin
  5. Salamander_King
    Salamander_King Senior Member
    11,004
    8,925
    New England
    Nop! Unless you can prove it is caused due to a manufacturing defect.
  6. will the engineer
    238
    119
    LA
    2019 Prius Prime
    FML!!!!!
  7. schja01
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    There is a 60 month unlimited mileage warranty against corrosion perforation but there are a lot of escape clauses so I consider it pretty weak but it is something I guess.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I take mine to my driveway for oil changes. I'll stick with the specified OC interval till the warranty expires. But it'll only have a couple thousand miles on the engine. I usually change sooner than spec anyway.
    Arctic_White likes this.
  9. bisco
    51,033
    i go to the local mech at the mobil station. oil and filter very 10k, tires very 5. lube the caliper pins every 30k and give everything the once over. i do the air and cabin filters, keep an eye on oil level, tires pressure and 12v.
  10. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    What service at 27,000? None is specified unless required by time.
    Did the dealership con you into some unneeded service like 3,000 mile oil changes?
    Anyway, any licensed auto repair shop can do the required work and cover the warranty requirements. You only need to return to the dealership for warranty claims. You can do the work yourself, and I do, but be ready to jump through hoops in case of a warranty claim on a part you worked on.
  11. frodoz737
    frodoz737 Top Wrench
    4,508
    2,428
    33
    Assuming you did get any flack...receipts are all you need.
    ...and those can be pulled off the puters nowadays.
  12. schja01
    1,814
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    ’60s? I remember Earl Scheib commercials “I’ll paint any car any color. $29.95”
    They just removed the hub caps, masked the chrome and windows and then painted everything including the metal wheels, tires and lug nuts. Then they painted the tires black to cover the overspray.
    Fast and cheap.
    #12 schja01, Mar 31, 2019
  13. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Actually, if you did your own prep work (Bondo, trim and component removal, masking etc.) it wasn't half bad. Back in the day, I was going to sell my trusty old Volvo and had it done with their Premiere grade paint for a few dollars more and liked the job so much that I kept the car a few more years. A key factor was proper prep (which you could not count on them to do) and keeping the color as close to original as possible to avoid trunk, hood, door jamb anomalies.
    Current day finishes are not without issues. One of our Hondas developed "hood rash" due to a faulty clear coat, a flaw Honda had with certain colors which took years to manifest. We had already given the car to our grand daughter (2000 miles from us) when the problem arose, but after sufficient prodding Honda did a repaint at one of their own body shops. As an aside, I've since noticed several Toyotas and other autos with that same problem.
  14. bisco
    51,033
    we have people here complaining about the paint on ten year old cars
  15. Mendel Leisk
    40,484
    I would keep a log file too. Note the date, miles or kms, and what was done. Maybe add a note to the receipts you have too: dealership parts dept receipts in particular are pretty unintelligible.
    They use to be a bit more meaningful; but recently got "improved":
  16. Washingtonian
    Washingtonian Senior Member
    726
    621
    I am wondering if it makes sense to change the oil every year on my car. It was changed by the dealer last month for the second time since new at the two-year mark. The car has 8000 miles, so I can expect to drive it another 4000 miles this year. Probably less than 500 miles will have been driven using the ICE. I checked the oil on the dip stick just before it was serviced and it looked perfectly clean. So my question is: Will synthetic oil used for only 500 miles deteriorate after twelve months to the point that it needs to be replaced?
  17. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    You have rain. (or your name and location are wrong*) Enough moisture will have built up in your oil to need to change it.
    You may also feel better with a warranty, so I would follow it's requirements.
    Even at dealer prices, $60 a year to protect a $30,000 investment seems wise. DIY might be half that.
    * he is going to be in that tiny sliver near Sequim that gets 15 inches of rain a year, I just know it.
  18. So the paint fades... what about a service to get a coat of wax put on, like, once each summer? Any places do that cheap?
  19. Mendel Leisk
    40,484
    I wax it spring and fall. DIY, you notice any ding and scratches, so have the touch-up paint ready.
  20. Trollbait
    12,319
    Need to be changed? No, the Volt would let its interval extend up to two years, but there is the concern about warranty coverage.
    If DIY, you could use a 5w20 synthetic blend to save a few dollars, or what I'd lean to, use the 'old' Prime oil in another car or lawnmower.
    Considering that the crankcase should be sealed if the the PCV is working, and even with an open open one, the majority of water that gets into the motor oil is combustion by-product. For every gallon of gasoline burned, a little over a gallon of water is produced. Most goes out the exhaust pipe, but some goes past the piston rings into the crankcase. Environmental water can make its way into the crankcase, but I suspect humid climates just make it harder to boil the combustion water off.
