Lowly fluorescent bulbs outdo Kyoto, Solar, Wind
Discussion in 'Environmental Discussion' started by TimBikes, Aug 28, 2006.
  1. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    The Kyoto Protocol if fully complied with would reduce emissions by about 12 billion tons over 25 years (483 millon tons year by 2012 X 25 years = 12 billion tons of CO2) at a cost of up to $1 trillion.
    "The low-energy light bulb and other efficient lighting systems could prevent a cumulative total of 16 billion tons of carbon from being added to the world's atmosphere over the next 25 years, according to a report by the International Energy Agency." (link: http://www.iema.net/news/envnews?aid=15436)
    "A global switch to efficient lighting systems would trim the world's electricity bill by nearly one-tenth...
    The carbon dioxide emissions saved by such a switch would, it concludes, dwarf cuts so far achieved by adopting wind and solar power...The carbon dioxide produced by generating all of this electricity amounts to 70% of global emissions from passenger vehicles, and is three times more than emissions from aviation, the IEA says." (link: http://news.bbc.co.uk/2/hi/science/nature/5128478.stm)
    And... they easily pay for themselves in energy savings. Available cheap at Costco.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Only two problems: dimming and color. True, halogens aren't efficient when dimmed, but you can do it. The color of CFLs is all over the spectrum, and changes over the life of the bulb.
    Most of the light switches in my house are dimmers, to save energy. I'd have to change switches to change lamps. I am used to the spectrum of halogen incandesent, most CFLs I have seen are discontinuous spectrum and make people, food, and objects look bad, and a lamp that looks sort of OK today may become quite blue in a couple of years.
    I'm all for saving energy, and reducing CO2, but I'm not sure CFLs are the way to go. Maybe high-frequency CFLs @ 20KHz, which can be dimmed, or LED/OLEDs. Technology needs to advance.
  3. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(TimBikes @ Aug 28 2006, 01:33 AM) [snapback]310442[/snapback]</div>
    I've switched *every* light in my house with the exception of the outdoor porch light over to CFL bulbs. In my opinion, there's no excuse not to do something like this.
  4. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I had the same objection to the color and feel of CFL lights, but I couldn't come up with a reasonable excuse not to switch all the lights in my house without feeling like a complete hypocrite. So I switched them. Most places you can get rebates or in-store coupons to make them VERY cheap too. I also got used to the new spectrum in a matter of days.
    Dimming is a luxury, when you look at it that way, and I don't think my desire for slightly different levels of light outweighs my responsibility to conserve energy (and save myself money).
    Maybe the solution for that is some sort of LCD lampshade that can darken itself to dim the light inside! ;)
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I've switched about 50% of my bulbs to CFLs, but have issues as Bill does.
    1)The 5 year life expectancy seems to be grossly overestimated. Many of mine burn out within 1-2 years. Particularly the ones I had on dimmers until I figured out that you can't use them with dimmers. But still, even on normal switches I'm changing these things out relatively regularly and have only been using them for 2-3 years. And we're not talking about rooms where the lights are left on constantly. On average I bet they're only on 4-5 hours a day in the rooms that are the most lit.
    2)The delay in turning on is annoying. So much so that in a few rooms I've left one standard bulb in (like a ceiling fan cluster with 4 bulbs I'll make 3 CFLs and one standard incandescent) just so they I get instant light when I flip the switch.
    3)Although they list a "as bright as" on the box, I'm skeptical. It might be a color spectrum issue in part, but I don't think they are as bright as advertised.
    4)I don't mind the cost of changing over my bulbs to CFLs if they do indeed last significantly longer than incandescent and can assure a reasonable ROI, but I'm becoming skeptical that the 'real world' mileage is going to live up.
    Trust me, I'm still wanting/trying to do the 'right thing', but my skepticism on the CFLs borders that of your skepticism of the Prius JohnnyCat.
  6. Ichabod
    1,794
    Newton, MA
    I find that mixing and matching CFL with incandescent or (ick) halogen only exaggerates the color spectrum issue, and I notice it less when I'm using only CFL.
    I've never had a delay when turning them on, so I'm not sure what that's about... and as for brightness, they take a few minutes to get up to full brightness, but once they're "all the way on," I'd say a 12 watt CFL is roughly equivalent to a 60 watt incandescent.
    Longevity: how long does a CFL have to last to equal the lifecycle of an incandescent? They use less juice, but judging by their construction they cost more and require more energy to manufacture. Stats?
    A promise of 5 years without changing a bulb seems optimistic, but I seemed to be changing incadescents a few times a year, and if there was a power spike I could count on a blown bulb.
  7. Jonnycat26
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(efusco @ Aug 28 2006, 09:15 AM) [snapback]310494[/snapback]</div>
    Well, I drive the damn thing... so I can call it like I see it. And as long as you have the bulbs, you can say what you want about them. :)
    However, I have found that the 'name' CFLs are better than the generics that I get at the local store. Specifically the Philips (available at Target) seem to have the best 'whiteness' to them. And the response time is fairly fast, generally only a few seconds, so that doesn't bother me too much.
  8. Alric
    Alric New Member
    1,526
    87
    <div class='quotetop'>QUOTE(TimBikes @ Aug 28 2006, 12:33 AM) [snapback]310442[/snapback]</div>
    To oil companies! Individuals would probably benefit from the new technologies and a stock market renaissance.
  9. dragonfly
    dragonfly New Member
    2,217
    I converted all my bulbs to CFLs a couple months back. The delay has gotten much better with the newer technology, I hardly notice it - it's certainly no more than a second, but I think less. Maybe it's a brand thing.
  10. naterprius
    naterprius Senior Member
    1,843
    I have put CFL's in places that I can. I must warn against putting one in the laundry room; it sucks when a stained shirt looks clean, is put in the dryer, and then you step outside...
    Nate
  11. Ichabod
    1,794
    Newton, MA
    ha ha! put a daylight CFL in the laundry room if you want that comparison. They seem harsh and overly blue by comparison though.
  12. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    <div class='quotetop'>QUOTE(Bill Merchant @ Aug 27 2006, 11:18 PM) [snapback]310456[/snapback]</div>
    True enough. I can get used to the color for the most part, though I don't like the increased glare. It is not a perfect solution, but using them in closets, bathrooms, and hallways is not too objectionable.
    I also agree their advertised life is not up to snuff.
    BTW, I'm no electrician, but my dad's electrician told him that putting a light on a dimmer really doesn't save any energy - aparently the circuit still draws as much power, the variable resistor just keeps it from getting to the bulb - presumably it is lost as heat at the dimmer. I can't vouch for that, but that is what he said.
  13. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    hmm, i guess i'm not too picky about my light then... since i haven't had any problems with the CFLs we installed a while back. we do get a lot of sunlight from the front windows during the day, but it still is fine at night.
    we don't have a time delay when we flip the switch. they come on at about 75% brightness and warm up to 100% within a minute or so. all the ceiling lights are CFLs, but we have a couple lamps that take a type B bulb that we haven't been able to find match for.
  14. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    <div class='quotetop'>QUOTE(Alric @ Aug 28 2006, 08:33 AM) [snapback]310546[/snapback]</div>
    You and I must be living in alternate universes Alric. ;)
    "The Department of Energy estimated that gasoline prices would have to rise 66 cents a gallon — or 53% over a projected 2010 price — to meet Kyoto's emissions targets." http://www.usatoday.com/news/washington/2001-06-12-kyoto.htm
    Cheers.
  15. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Ikea has routinly had them for $1.33 each <3 for $3.99> and the ones they sell turn on instantly though it takes about 10 seconds for them to reach full brightness. I have had many of my CF's last five years, I have a few that are eight years. Some do die early but not enough to bother me.
    The light quality is also quite high on the Ikea bulbs. I find them different but not less pleasent then regular bulbs.
    Dimmers dont really save money compared to CF bulbs, a dimmed regular bulb takes more power then a CF running at full. Dimmers do provide a usefull function of course if you WANT the light dimmed. :)
    In the next few years expect to see LED bulbs with better light color and more durability compared to CF. At some point they will cost less too but that may be a decade from now.
  16. AuntBee
    AuntBee New Member
    2,383
    Middle Tennessee
    I had never seen/heard of the CFLs until last spring when my power company sent me a free one with my Earth Day Care Package. It's a GE 60 watt bulb and I am using it now in the floor lamp beside my computer desk. Haven't decided if I like it well enough to invest in more of them. I haven't observed any delay mentioned in above posts. Color takes a little getting used too, but not too offensive.
  17. Bill Merchant
    4,096
    85
    <div class='quotetop'>QUOTE(TimBikes @ Aug 28 2006, 08:53 PM) [snapback]310959[/snapback]</div>
    OK, the full story is that I have lots of X-10 switches and the lights are computer controlled. I uses "scenes", like a button for early morning that turns on the kitchen downlights at 30%, the light over the sink at 50%, the light in the utility room where the dog food is at 40%, and some of the living room lights at 30%. A gentle way to start in the morning. As I wake up I raise the light levels and turn off the lights in the utility room.
    These electronic switches do not use as much electricity as a regular circuit when dimmed. If full bright is full voltage all the time, the dimmers reduce the voltage and cut the on duration. At 50% bright, the circuit uses about 50% of the energy as full bright would use.
    I'd like to have LED lights with red, green, blue, yellow, and while LEDs, with controls so I could adjust the brightness of any particular color to manipulate the overall color temperature of the light output. Still discontinuous spectra, but a better color balance, and adjustable. The circuitry to allow dimming LEDs actually just cuts the on time, so 30% bright is really on 100% for 30% of the time. If you increase the base frequency from 60 Hz that comes out of the wall to 20,000 Hz going into the fixture (this gets it above human hearing so you don't hear the dimmer whine) you can choose which time-slices to power with fine granularity.
    The nature of a flourescent bulb is that a tiny bit of metal, frequently mercury, is used to start a plasma from one end of the tube to the other, even the curly tubes of CFLs. Wall voltage of 110V is stepped up to several thousand volts. The plasma emits high energy photons and electrons which strike the coating of phosphors on the inside of the tube. A mixture of phosphors are used to get a particular color, but each phosphor only emits in a fairly narrow spectral range. The phosphors which produce the biggest downshift, from the ultraviolet of the plasma to a reddish color, also degrade the fastest, so the bulb becomes bluer over time. It's not easy to start and stop a plasma, so dimming is not simple. If the voltage goes too low, the plasma stops. Increasing the frequency and cutting the on cycles can get around this some.
    Maybe a better choice in the near term are high-intensity discharge lamps, like the Prius headlights. By mixing the right gasses, you can get a good white. Bright without much wattage. I've noticed what look like PAR lamps in commercial fixtures that are clearly HID. But there's still the problem of having fewer lumens when you don't want them, like first thing in the morning.
  18. Jonnycat26
    1,748
    New Brunswick, NJ
    Sort of off topic, but what the hell... :)
    I just picked up a solar motion detector floodlight for my backyard. I had wanted to get a regular one put in, but on a whim googled to see if there were solar powered versions available, and after seeing that there were, I bought one. It's one of the better ones because the solar panel can be placed up to 15' away from the light itself, which allows me to find optimal placement for both the light and the panel.
    One of my friends suggested getting 5, but I doubt the neighbors would like my backyard lighting up like the late, great Veteran's stadium every time a raccoon made a dash across my yard.
    I'm not sure how much energy this rig will actually save because I'm not sure how much power the detector actually takes to run. But even if it saves very little, the little it saves won't be coming from the grid.
  19. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    <div class='quotetop'>QUOTE(Bill Merchant @ Aug 29 2006, 12:02 AM) [snapback]311005[/snapback]</div>
    I think you are right Bill - I saw this online ...
    "Solid-state dimmers now on the market can save up to 50% of lighting energy used and cost only about $4 per unit. The older type dimmer did not save energy for it varied light availability by converting energy into heat."
  20. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Yeah, the old dimmers just jacked up the resistance across the circuit, I believe. Glad to hear that the newer ones are a lot smarter than that. The small added benefit is that the incandescent bulbs installed in the dimmers will put out less heat thus saving on cooling costs. Personally, we use CFL bulbs and have generally been pleased with their performance. During the day we don't use any artificial light simply because we don't need too. It keeps the house cooler and we turn the swamp cooler on later in the day than we would otherwise.
    One thing that gets me about the CFL bulbs is how some light sockets seem to allow the bulbs to come on directely at some level close to 100%. Other fixtures seem to cause the bulbs so ramp up to 100% much more slowly. I've used the same bulb in different fixtures and gotten different results. Any ideas?
